700r4 wont shift into 2nd 3rd or 4th
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: 700r4 wont shift into 2nd 3rd or 4th
stripped governor gear is a common cause of that problem. Easy fix.
thanks man but I already checked the governor and it's fine . I have been told that it should shift if you Rev it high enough if the tv cable plunger is stuck but it won't shift at all . We'll it will shift into Rev or neutral and park just fine and the 4x4 seems to be working fine
Car: 1991 camaro Z28
Engine: Forged 370" LS turbo s488
Transmission: Built 4L80e FTI converter
Axle/Gears: MWC 9" 35 spline 3.25 gears
NEOMASTERZ28
Mar 20, 2002 11:46 AM
