1999 C5 4L60 internals in 1988 f-body TH700R4
Old May 3, 2025 | 04:22 AM
seb.a's Avatar
Car: 1983 Trans Am MSE
Engine: LG4
Transmission: TH700R4
Axle/Gears: 10 bolts 3.73
Hi everyone!
I was wondering if there are some internals from a 99 C5 corvette 4L60 that could be used to improve a TH700R4 from a 1988 Firebird (with the L03 engine).
I have both transmission at home and noone seems interested by the Corvette gearbox so I was thinking about improving the 700 using parts from the C5 trans.
The gearbox will be later set on my 83 MSE trans am and may be mated to a LS engine. I'm looking for 350 to 450HP at the crank. The will remain a reliable cruiser for Sunday and holidays. No racing.
I didn't find any post about that but if that subject has already been treated, please send me the link.
Thanks.
Old May 3, 2025 | 10:10 AM
mjgord51's Avatar
Car: 14 & 96 Camry's, 68 C10,70 Z28
Engine: Depends what vehical I'm driving
Transmission: Also depends which vehical
Axle/Gears: Also depends on vehical
Re: 1999 C5 4L60 internals in 1988 f-body TH700R4
FYI - GM's 4L60 non E trans stopped production in 1993 for Corvettes and 1 or 2 other cars. And the 4L60 E trans first came out in 1993.
No such thing as a "1999" 4L60 non E coming from the Corvettes. 4L60's were dead in the water in 1993...
Old May 3, 2025 | 10:51 AM
seb.a's Avatar
Engine: LG4
Sorry about that E i forgot.
No doubt these are not the same a the 700 is using cable on the throttle while the 4L60E is computer managed.
The question is ; is there any internal like 2-3 servo i could use from the C5 trans on the 700R4 ?
Old May 26, 2025 | 05:20 PM
mjgord51's Avatar
Both 700R4 and 4L60 (basically same trans different years namings) both use a cable from the carb for its pressure shift points. With or without a cable 700R4 or 4L60 (non E) ended in 1993 - NO such 1999 C5 Corvette "stock" usage.
Old May 29, 2025 | 05:03 PM
Pro Built Automatics's Avatar
As for the internals (rotating parts only), you can use here. The only part that will not work is the output shaft.
MarineIROC
May 23, 2010 03:04 PM
