Help with replacing TH700r4 in 85 Trans Am
Old Jun 1, 2025 | 12:57 PM
Smuggler's Avatar
Hi, I have a 1985 Pontiac Firebird Trans Am with the stock carbureted 305 and a th700r4 transmission. The transmission has been nothing but problems for me for the last 5 years, every time a put a seal in it leaks somewhere else and is shifting incredibly hard into each gear...
I've been looking at some options to replace it and was wondering if anyone has put a 4l60 in there firebird/Camaro as a replacement. I'm on a tighter budget and trying to find something I can put in myself without having to modify the driveshaft or rear end. I don't have a problem making up a cross member for the car.
Will the 4l60 directly fit into this car?
Can I use a 4l60E without adding electronics?
Should I just find another 700r4?
Any help would be appreciated, not sure how much longer it will stay on the road with the current trans.
Old Jun 1, 2025 | 01:34 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
Re: Help with replacing TH700r4 in 85 Trans Am
How many miles on the transmission? which seals are leaking now? The hard shifting may be broken accumulator spring(s)- a quite common problem or Throttle cable badly out of adjustment.
- 4l60 just a name change about 1990-i think pass car trannys through '92 likely will work.
-4L60E will not work
-not a bad idea-depending on what you can find in 2025...
Fixing the tranny in the car now probably easier than locating a suitable replacement and then swapping unknown,possible defective tranny in and trying it.
Old Jun 1, 2025 | 07:23 PM
bk2life's Avatar
Veteran: Army
Car: 91 WS6 GTA
Engine: 5.3
Transmission: 4l60e
Originally Posted by Smuggler
. The transmission has been problems for the last 5 years,.
pull the 700 out, get it rebuilt, reinstall it, dont have any more issues.
easy peasy lemon squeezy
Old Jun 3, 2025 | 05:21 AM
Smuggler's Avatar
Transmission only has 134000km on it, seems to slip a little in 4th but only at random and at higher rpms. Perhaps I adjust the TV cable and see about the shifting. My friend told me he has a working Turbo 350 I can buy off him so maybe that's a better route. It's unfortunate that my local scrap yard crushes anything older than 20 years... I'll look into the accumulator spring or rebuilding it. Was quoted $2000 for rebuild (removed from car), kit is $250 but I've never opened an automatic other than to change a filter.
Pump O-Ring / Gasket is currently leaking
dctrouant1995
Apr 5, 2014 10:51 AM
Dairy King
Jan 12, 2007 06:10 PM
myfast3rdgen
Sep 18, 2004 09:27 AM
MaximumRacin
Nov 10, 2001 01:46 AM
