1986 5 speed
Car: 1986 Blue Iroc Z TTop
Engine: 305 LG4
Transmission: 5speed
1986 5 speed
I'm swapping out my 305 for a 350 with about 345hp. Will my borg werner 5 speed be able to handle that much for a cruiser? Car is a 1986 iroc z with original trans and rearend.
Re: 1986 5 speed
Depends on your driver.
People have torn those up with a 6-cyl. Others have made em live behind a 400. Depends on how it's driven.
Car: 82 TA
Transmission: Magnum f
Axle/Gears: Ford 9 w 4.11
Re: 1986 5 speed
Yes and no! Yes if it's in good shape and cautiously abused it should hold up. I had a zz4 hooked to my t5 for years. I did plenty of tire spinning and had fun. But I was always cautious. That said, It you have a posi, wide and sticky rear tires and a solid clutch, then launch it w a 4k rpm clutch drop you will find out how quickly you can kill a trans.
Car: 1983 Z28
Engine: 385 Fastburn
Re: 1986 5 speed
Yeah just be aware of how it's driven, run it for as long as you can and just be prepared to swap for a TKO or similar when the time comes.
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Car: 82 TA
Re: 1986 5 speed
There's a complete t56 swap for sale on this board for an awesome price.
just a thought!
just a thought!
