TH200C is in drive regardless of shifter position
Just bought this car. Thank goodness it is up on stands because I just got it running today. Problem is that the shifter was in Park position and when the car started up, the wheels immediately were turning forward. As it idled, I moved the shifter back and forth - that had no effect on wheel speed or direction the wheels turned. Even though cables are attached, I didn't feel the shifter hitting notches for P, N, R or D. This is my first car project ever so am learning as I go! Any thoughts on what is going on?
Car: '83 Firebird (T/A Clone)
Axle/Gears: 10-bolt/3.73 ..
Re: TH200C is in drive regardless of shifter position
Did the shift cable become disconnected from the shift lever on the transmission?...
Car: 1992 Pontiac Firebird
Engine: 5.0L L03 TBI
Sorry I didn't reply sooner. I don't think it disconnected at the transmission. I did remove the shifter from the door but let all the connections in tact. I needed to get beneath the shifter assembly to sand out some rust
Car: 1982 MSE, 1988 S10 Blazer
Engine: 305 in both!
Transmission: 200c / Th700r4
Axle/Gears: 3:73 / 3.42
You need to check the linkage ear on the trans. That clip CAN/DOES sometimes pop off and leave the cable just dangling without moving the ear.
