Building 700r4?
Old Jan 26, 2002 | 01:13 AM
RedFirebird's Avatar
Car: 1988 Trans Am GTA
Engine: 5.7L TPI (L98)
Transmission: 700RJunk
Building 700r4?
Okay i currently have the stock 700r4 tranny in my gta with roughly 100k on it. Works fine right now but 220 HP isn't cutting it and thats gonna change (maybe 280-330 range). So i want to beef up my tranny and i was thinking of getting one of these B&M rebuild/overhaul kits, a stage 2 shift kit, and possibly a mild stall converter. What else do i have to do to make it handle any kind of power? How much would it cost to have someone do the rebuild? I was considering attempting a t56 swap but i decided not to because of the difficulty involved and i want to keep my car, in terms of original options, stock.
Old Jan 26, 2002 | 02:18 PM
Yvonne's Avatar
700R4 Where's the beef?
I sound like a broken record on this forum... Upgrade, dear. Some shops make a "performance" R4, but most don't. Why? It's not cost effective. You almost always have to upgrade past it. The tranny is okay for the street rod which comes out for a few events per year, but for most of us it would be a poor option.
Old Jan 26, 2002 | 10:29 PM
jamesbern's Avatar
A 700R4 will be fine if you get all of the updates done to it, have the extra clutches put in the 3-4, heavy duty sprag, and a Transgo or similar shift kit installed. Don't use the B&M kit, most members will tell you to use the Transgo kit, and I agree, but there are slightly better kits that include more upgrades. My 700 is fine behind a 383 with about 440 ft./lbs torque. I used a 2000 Stall out of a Vette because it is cheap and it is just right for my engine. good luck!
Old Jan 26, 2002 | 11:54 PM
88WS6TA's Avatar
"most members will tell you to use the Transgo kit, and I agree, but there are slightly better kits that include more upgrades."
What are they and where do I buy one??????
Old Jan 27, 2002 | 02:18 PM
jamesbern's Avatar
Go down to your local transmission parts distributor and check them out. Let me warn you beforehand these are not simple 30 minute install kits, they are in depth and not for the average first timer. I had expert help with mine and it is fine. All I can remember is that it was made by Superior.
Old Jan 28, 2002 | 02:47 AM
Pro Built Automatics's Avatar
Give me a call on this, as this is my specialty (performance parts & tech advice). My kits come with everything (Trans-Go, Borg-Warner, boost valves, Hi-Energy clutches & band,etc.) that is required to do the job correctly. If you have any questions please call me at 800 7763288 M-S 10-6 PST. If you get a chance check out my website www.pro-built.net Let me know if I can be of help.
junior419
Apr 7, 2025 11:35 AM
RyanJB
Members Firebirds
39
Nov 20, 2018 03:30 PM
plm99
Southern California Area
Nov 16, 2015 05:21 PM
Jorlain
Oct 8, 2015 01:57 AM
89newfun
Sep 16, 2015 09:28 AM
