first third gen camaro its the 84 berlinetta
Old Jan 26, 2002 | 09:31 AM
in_hell_i_reign's Avatar
it needs a lot of work. the trans is burn and i have had a hard time finding info on the berlinetta. i have action on a 350 and i was wondering if it was a strait bolt across or will their have to be modifications done to the drive shaft and any more tips would be of great help. want to start today. thanx
Old Jan 26, 2002 | 10:16 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Re: first third gen camaro its the 84 berlinetta
Kinda confused here
If it's the berlinetta it should be a 2.8 and therefore you going to need a tranny for a 2.8 either a 200c or 700R4, if your car is an overdrive (P,R,N,O,D,2,1) then its a 700r4. Now if someone put a v8 in there than a TH350 will fit as long as you get a xmember and a drive shaft from an 82 (200c).
Good Luck!
SSC
Old Jan 27, 2002 | 01:53 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
The 350 will fit
If you are referring to a 350 tranny - yes,... I'm pretty sure you will need a different driveshaft. I believe that there is also a kit availible in the performace parts magazines for this tranny swap.
If you need information about your Berlinetta, E-mail me & I'll do what I can for you. Check out my Website too ---
Enjoy your digital camaro !
Attached Thumbnails first third gen camaro its the 84 berlinetta-berlinettawebsite2a.jpg
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
1992 Trans Am
Exterior Parts for Sale
Apr 4, 2016 12:50 PM
I'llrocya
Feb 2, 2016 11:43 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
