T56 conversion help/parts needed!
Car: 87 GTA
Hello,
I'm currently in the middle of converting my '87 GTA from an A4 to a 6 speed. I intend on using a 3rd gen master cylinder with the 4th gen slave cylinder ('cause I just happen to have those lying around). Unfortunately I need the 4th gen hydraulic line from the master to the slave because the 3rd gen line won't work. Does anyone have one that I could obtain / buy for a reasonable $$$? I'm sure someone has one lying around because when you change master/slave cylinders (in a 4th gen) it comes in a complete kit. I'm trying to avoid the $150 or so on a new master/slave cylinder from a 4th gen, and the junkyards don't have them 'cause when they pull engine/trans out that's the first part they snip. (bastards!)
thanks
Arnaldo
thanks
Arnaldo
Car: 85 iroc,96 z28,96 Ram 2500,69RR
Engine: 383 with AFR heads.
Transmission: richmond 5 speed
Axle/Gears: 1991 w/1LE.auburn pro series.2.73's
couldnt call it "bled" because its not, really. comes complete from master to line to slave all filled up and ready to bolt on the car.
BlackphantomZ28
Aug 31, 2015 10:29 AM
