700R-4 question
Old Jan 29, 2002 | 09:04 PM
cwalsh's Avatar
Car: 2004 Corvette
700R-4 question
This is for anyone who has had a 700R-4 fail. My question is what gear failed first?
Old Jan 29, 2002 | 09:24 PM
Jay 727's Avatar
Had one lose fourth, a few miles later lost third and second, it was a stripped governor gear.
Never had any other problems.
Usually it's the third/fourth clutch pack. I have seen a few cores with stripped out forward clutch splines.
Old Jan 29, 2002 | 10:07 PM
cwalsh's Avatar
Car: 2004 Corvette
just wondering mine seems to be slipping in 3rd now
Old Jan 29, 2002 | 10:46 PM
Jay 727's Avatar
It's probably the clutch pack. I have a rebuilt 1990 700R4 that has a few mods, no kit. It slipped at full power 2-3 shifts. I changed the 3-4 clutch stack clearance from stock specs (.049-.113) mine was .089, I tightened it down to the transgo recommended .035, it doesn't slip now, even with an estimated 360 HP.
You'd be better off with a rebuild at this point (depending on mileage). If it gets rebuilt make sure the clearances are not set to factory specs.
Old Jan 30, 2002 | 04:13 AM
transfixleo's Avatar
Some years ago I did failure analisys on all of the 700's that came into the shop for quite a while and to my surprise I found about an equal distribution of Forward Clutch, 2/4 Band and 3-4 Cltuch failure, not counting hardparts related failures which are normally lube related. I expected to see it more Band or 3-4. I do tend to think on Hi-Po vehicles that we see the 3-4's show up first but the bottom line was that all three of those failures were usually traced to the same thing: Pressure Rise malfunction. The TransGo SK/Reprogramming Kits both address this problem and fix it.
Old Jan 30, 2002 | 06:28 AM
cwalsh's Avatar
Car: 2004 Corvette
Thanks guys. I am going to try and make it last until spring so I can get all of my 6spd stuff together.
fasteddi
Sep 10, 2015 09:32 AM
masonta
Sep 1, 2015 06:40 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
