speedo cable
Old Jan 31, 2002 | 03:55 AM
jarek5_7's Avatar
speedo cable
my speedometer cable i maing squeki noise. i`m gonna do some thing on saturday and I want to lubrificate it.
Waht is the best and easy way to do it?
its TH700R4
Old Jan 31, 2002 | 05:26 AM
Jza's Avatar
Jza
Take out your dash cluster. You'll see the end of the speedo cable when you disconnect it from the cluster. Use some needlenoses and pull it all the way out of the cable sheath.
Then run it back into the sheath through a glob of grease in your palm. Some years use a two piece speedo cable. Sometimes, lubricating just the top piece is enough to stop the squeak (at least inside the car), but if not, then you'll have to pull the cable all the way out to lube the rest.
Z28/ZR1
Oct 23, 2015 01:04 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
