Anybody got transmission case length info??
Old Feb 3, 2002 | 12:10 AM
86TpiTransAm's Avatar
Car: 1986 Trans Am, 1991 Firebird
Engine: 355 TPI, 3.1L V6
Transmission: 700R4 in both
I'm looking for the case length specs for the TH200, TH350, and TH400 ... if anyone has these specs or a website that has these specs listed I would greatly appreciate it. Thanks in advance.
Old Feb 3, 2002 | 08:23 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Total length (bellhousing to rear seal)
TH200 = 27 5/8"
TH350 (short tail shaft) = 27 5/8"
TH350 (long tail shaft) = 30 5/8"
TH400 (short tail shaft) = 28 1/4"
TH400 (long tail shaft) = 34"
700R4 = 30 3/4"
200-4R = 27 3/4"
4L80E = 31 1/2"
TH250 = 27 5/8"
PG (short tail shaft) = 24 1/4"
PG (long tail shaft) = 27 1/2"
Mounting length (bellhousing to tranny mount)
TH200 = 20 1/8"
TH350 = 20 3/8"
TH400 (short tail shaft) = 26 3/4"
TH400 (long tail shaft) = 28"
700R4 = 22 3/8"
200-4R = 26 7/8"
4L80E = 30 3/8"
TH250 = 20 3/8"
PG (short tail shaft) = 19 1/2"
PG (long tail shaft) = 20 1/2"
Good enough?
Old Feb 3, 2002 | 08:33 AM
Jay 727's Avatar
Here are some actual measurements I just took.
700R4 30 3/4"
th350 with 9" tail 30 3/4"
th350 with short tail 28"
short th400 28 1/2"
Old Feb 3, 2002 | 08:43 AM
Jay 727's Avatar
Heres more with the 200 info.
http://www.angelfire.com/80s/monte/transmis.htm
Old Feb 3, 2002 | 05:30 PM
700R4 30 3/4"
short th400 28 1/2"
These sound better. Stephen, are you sure your records are right? You show the 700R4 only being 1/8" longer than the TH350 short tail and I'm pretty sure it's more like 2 3/4" like Jay shows because when I replaced my 700R4 with the TH350, the adapter block (so you can use the same driveshaft) was more than 2" long.
The main reasoning behind my questions about case lengths is because the S-10 I'm getting originally had the TH200 and I know the TH350 can be bolted directly in place using the same driveshaft and everything but I'm wanting to put a TH400 in there instead and was wondering if there would be too much difference between the TH350 and the TH400 to be able to use the same driveshaft. The crossmember location is not a big deal to relocate so I'm not too worried about that part.
(Just as a kind correction... it's a 200-4R, not a 200R4. I've seen lots of people call it a 200R4.)
Old Feb 3, 2002 | 06:10 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Oops. I had an error. The correction has been done. Those measurements are from an article on tranny swaps. December 1993 Chevy High Performance.
It was too early in the morning to type all those numbers.
Old Feb 3, 2002 | 06:23 PM
That sounds better Thanks for the info.
AussiePr0nCar
Mar 6, 2020 04:04 PM
midge54
Dec 27, 2019 04:14 PM
Cornholio7979
Sep 20, 2018 02:31 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
