will a B&M shift kit really help any?
Old Feb 3, 2002 | 03:49 PM
MattW's Avatar
Car: 1984 Trans Am
Engine: Vortec 355
Transmission: TH-700R4
Axle/Gears: GM Axles and GM 3.73
i saw a shift kit for like $30 at autozone for 700R4
now will this really help....will it make my car chirp in the gears and improve my ET's?
how high do they usually shift at......if i did get it would u suggest the stage 1 or stage 2 kit?
whats the diff?
and also are they hard to put in?
could i do it by myself?
thanks
Old Feb 3, 2002 | 05:17 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
The only thing it will do is firm up the shift. It won't fix the problems that are in the 700R4.
Old Feb 3, 2002 | 09:57 PM
iroczul8r's Avatar
Well, the guy who owned my car before me put a shift kit in, and it'll chirp when it hits 2nd gear. But after he put it in, it broke one of the transmission mounts b/c it was shifting so hard, so be careful about that.
Old Feb 3, 2002 | 11:05 PM
Flash84Z28's Avatar
Car: '03 S-10/ '87 Trans Am
Engine: mild 350
Transmission: TH350
I've got some wicked shift kit in my TH-350 that the shop I gave it to put in there with 5500 rpm shift points. I just broke the stock tranny mount, put in the ES poly mount, and now my x-member is cracked. I guess I'll go with the Spohn x-member. My kit definatly improved my e.t. although I haven't taken it to the track yet.
-Matt
Old Feb 3, 2002 | 11:24 PM
r90camarors's Avatar
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
it helped me
Mine had a shift kit installed when I bought the car. I'm not sure what brand or stage it is, but it definetly shifts beter than other f-bodies without a shift kit that I have rode in. Mine shifts hard into second, and usually kicks me sideways. 2nd to 3rd kinda sucks though, so I usually keep it in 2nd for 3-4 more mph than it would normally shift, and I always get a firmer shift like that. Hopefully, my auto will be out really soon.....though I've been saying that for a while now. Da#% the T56 swap!!!! It will be worth it in the end though!
Old Feb 3, 2002 | 11:38 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
Transmission: Slipping
When I first bought my Iroc it had a TransGo shift kit in it and the shifts were fast and firm. That transmission died (soon afterwards) and I put a B&M shift improver (from Checker auto) into the next one and it shifts pretty good... but I'd say if you wanted neck-snapping shifts, the TransGo kit is better. Plus, it's been said that it's supposed to be a better kit that fixes some of the shortcomings of the 700R4, but it does cost more.
Old Feb 4, 2002 | 12:26 AM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Matt, If you use the B&M kit insatll the RV/tow plate instead of the street/stip. The RV one gives you good firm shifts that dont feel half assed. Or just bite the bullet like I did and get the transgo kit. Alot of the S10 V8 guys I know love the B&M kits but they all hate the S/S plate, to fake feeling.
SSC
Old Feb 4, 2002 | 03:15 AM
Jza's Avatar
Jza
TH350s like the B&M shift kits much better than the TH700s do. I would never put a B&M into a 700, but I'd possibly put one into a 350 if someone asked.
Old Feb 4, 2002 | 03:57 AM
Pro Built Automatics's Avatar
Since 1977 I have removed hundreds of B&M, Art Carr, Superior etc. valve body kits from the different units I was working on at the time, REASON1) broken parts. (2) Burned clutches and/or bands. (3) Cheap, inferior lining or the wrong application of clutches/bands were used. (4) Brutal shifts on the 1-2 at light throttle (blocked accumulators) and.... and soft 2-3 shifts (not enough oil at WOT to the clutches) at full throttle. (5) Valve body modifications that did not address/solve the problems that were inherent in the transmission from the begining. (6) Etc. These transmissions did not even qualify as a "good core". Trans-Go is the "ONLY ONE" that does offer "fixes" & "solutions" to the problems inherent in all automatic transmissions, and still giving you the performance shifts you want.
Old Feb 4, 2002 | 10:40 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
What's the actual part # of that TransGo kit? I know there's a few kits by them... the "performance" shift kit, and the "fixing" shift kit- or is there a part # that covers them both?
Old Feb 4, 2002 | 03:21 PM
Call me at 800 7763288 M-S 10-6 PST and I will help you out on this.
Old Feb 4, 2002 | 10:02 PM
HOT89GTA's Avatar
MINE HAS HELPD ME AND IT STILL CHIRPS IN TO SECOND.MINE IS FOR AN AUTOMATIC THOUGH . ITS A B&M AND WAS O IT WHEN I BOUGHT THE CAR .I ALSO HAVE A SHIFTER BUT HAVE'T PUT IT IN YET AND DONT KNOW IF IM GOING TO OR NOT.
Old Feb 5, 2002 | 06:27 PM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
I have had the B&M kit for over 5 years now and have had no problems. Gotta be careful in the rain cause the tires will break loose when it shifts even at half throttle.
Old Feb 5, 2002 | 06:36 PM
Ezey Go's Avatar
I have the B&M street/strip kit in my car and I ahvent had any problems with it.Its been in the car about a year and a half.
Old Feb 8, 2002 | 12:28 PM
Momar's Avatar
I have the B&M kit in my tranny(every thing, not just shift kit). I have not had problems with it and it shifts great. If it does ever die on me though, I think I will get a newer 700 and put the transgo kit in it because it is supposed to be better on the tranny and fix some problems. Right now it is in my 85. I would have gone with transgo if I had talked to people on this board before I did it, but I didnt even know the board existed at the point. My cousin who is ase certified in transmissions built it so I got it for the cost of the parts. I dont think I will lose a lot(in terms of money) if it breaks but it has served me well so far.
Ben
Old Feb 8, 2002 | 01:35 PM
mattRS's Avatar
how hard is it to put in a shift kit? i dont know if i trust myself with all the check ***** and all. how much would a tranny shop charge for install?
Old Feb 8, 2002 | 02:05 PM
Synapsis's Avatar
Car: Sexy
Engine: Stock
It wasn't that hard for me. If you take your time and double check each step, installation is possible for someone with some mechanical ability. I only had three issues that required extra effort on my part.
1) The instructions didn't say the valve body was *that* heavy... my spaghetti arm barely caught it when it came loose.
2) I didn't have any grease to hold the check ***** in place when I was reassembling it initially. It's required since 1 or 2 of the ***** have to hold against gravity with nothing under them.
3) Transmission fluid just kept coming from everywhere. I knew there was a lot of fluid in there, but it didn't stop dripping the whole time I was working on it. I filled two containers with fluid.
It took me around 4.5 hours. That's using an air ratchet to save time (loosening only), but also looking for grease and constantly cleaning up fluid.
Old Feb 8, 2002 | 02:12 PM
Momar's Avatar
Just out of curiosity, what is required to install the 4th full throttle upshift (valve?)? If I were to do this should I use the gm version or the b&m? I remember someone saying something about it upshifting into fourth too early or something though. Does anyone know if that should happen or if it can be fixed so that it wont?
Ben
1Aauto
Sponsored Vendors
Jan 15, 2016 06:26 AM
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
1Aauto
Sponsored Vendors
Sep 10, 2015 02:02 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:50 PM
1Aauto
Sponsored Vendors
Sep 2, 2015 01:35 PM
