drive shaft question...
Old Feb 5, 2002 | 07:22 PM
Blade69's Avatar
does the drive shaft rotate at the same speed that your tires are rotating or does it rotate at the same rate as the RPM????
Old Feb 6, 2002 | 06:49 PM
Blade69's Avatar
ANYONE?!?!?!??!!??!?!
Old Feb 6, 2002 | 09:38 PM
Camaro8316's Avatar
From what I've heard...... if you have, say, 3.73 gears- if you turn your wheels one whole time around, your driveshaft spins approx. 3.73 times. Dont take this as truth till someone verifies, but I'm pretty sure.
Old Feb 6, 2002 | 10:38 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
Neither actually. If you take the engine speed and devide it by the current transmission gear you'll get driveshaft speed. Aka 3000 RPM / 3.06 gear= 980.4 driveshaft rpm.
And to get the RPMs at the wheel you devide the driveshaft speed by the rear end gear: 980.4 rpms/ 3.73 rear end= 262.8 wheel RPM.
David
Old Feb 7, 2002 | 05:13 PM
Ray Burrows's Avatar
If you are in 4th gear or highest gear before overdrive, most transmission will be 1:1. Meaning your driveshaft is turning the same RPM as the crankshaft.
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
Ozz1967
Aug 16, 2015 10:23 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
