Reverse lights
Old Feb 13, 2002 | 10:30 PM
usa1racing's Avatar
Reverse lights
Anyone that's switched from a 700R4 to a T5, how did you wire your reverse lights?
Matt
Old Feb 13, 2002 | 10:42 PM
robert C's Avatar
trying to figure that one out right now, its one of the wires from the auto shifter. i think ,just have to find out witch one havent looked yet i,ll let u know tomarro
later rob
Old Feb 13, 2002 | 10:52 PM
usa1racing's Avatar
my wiring daigrams say light green.I know there's a plug on the side of my tranny with two holes in it. and there's a plug i took out of the auto tranny with the two males ends to fit into the holes, but it has yellow and purple wire like the ones that should go to the clutch start switch.. however, i jumped theheavy purple and yellow wires and to test this, try to pop the trunk if you have an electric hatch release. With the auto mine wouldn't op unless it was in park or neutral, and when i jumped the two wires it will opo, so it must be telling the car that it is in park or neautral and it SHOULD bypass the clutch start switch.
Old Feb 13, 2002 | 11:25 PM
robert C's Avatar
looks like dk blue to the auto shifter switch, and lts green from switch to tranny.so if u hooked up the blue to the trannys reverse
output it should work.
my mph is a yellow and purple both small. the auto tranny dont have a reverse output its on the shifter
all i did with the clutch start switch is {bypass} just take the switch off the auto shifter and plug it in and your {bypassed}
make sure the switch stays in park
later rob
Old Feb 14, 2002 | 12:02 AM
robert C's Avatar
sorry my bad the lt.green one goes to the reverse lights not the tranny
the blue is probley, hot and the green completes the circut witch turns the lights on
later rob
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Jetmeck
Sep 4, 2015 12:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
