Who's running the SLP take-off diff with Moser 28 spline axles?
Old Feb 14, 2002 | 01:43 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
Friday I'm ordering this stuff and wanted to know who else is running it. Once I get my trans and engine straightened out, I'll be somewhere in/near the low 13s. I don't see this power level causing many problems to the diff, but I wanted to get other people's ideas.
I can't pour money into a 9" until I get a 6 speed and more engine upgrades, and I think a beefed-up 10 bolt should do fine until I get those engine upgrades.
While I'm in there, is there any other stuff I should replace for the sake of strength?
Old Feb 14, 2002 | 06:11 PM
onebad82z's Avatar
Car: 1982 Z28
Engine: 355
Axle/Gears: 12 Bolt
Weld the axle tubes to the center of the rear and run a solid pinion spacer from http://www.ratechmfg.com .This should make a pretty strong rear to get you into 13's easily.
Old Feb 19, 2002 | 12:31 AM
KevinP92Z's Avatar
Car: 92Z, 96RamAir, 91 4X4 Burb
Engine: 383 Super Ram, LT1, 350 roller
Transmission: 700R4, Probulit 700R4 &4L60E, 4L80E
Torsen/Mosers
I've got the SLP Heavy Duty Torsen diff with Mosers in my 92 now. I've also just received the Mosers for the '00 SS 4th gen rear I'm now building up for the Z (to get rid of the spacers since I'm running 17x9 SS rims)
The only problem I had with the 1st set of Mosers is that they weren't finished to the right length, so the "paddle" of the Torsen wouldn't slide in. Had to machine the length down. Then I discovered that the outside diameter of the axles was too big and wouldn't fit the groove in the sides of the paddle. Once this was resolved, no problems.
This time around, I knew what measurments to look for, so I've checked already.
By the way, I do have the oem Torsen in my wife's 96 T/A wRam Air.
hectre13
Dec 11, 2023 08:14 AM
fonzie85
Exterior Parts for Sale
39
Mar 16, 2016 07:07 AM
draco
Oct 4, 2015 09:25 PM
E Rod
Aug 28, 2015 05:17 AM
red90IROCls1
Aug 25, 2015 06:56 AM
