700r4-t-56 swap
Old Feb 15, 2002 | 09:21 AM
19WS6T/A91's Avatar
700r4-t-56 swap
I want to get rid of the 700 r4 and get a t-56. i was just wondering what i will need to complete the swap. Obviously i will need the console, pedals, and the transmisson what else will i need?
Old Feb 16, 2002 | 05:52 PM
u r sofa king we tah did's Avatar
that and...
bellhousing, clutch disc, flywheel, pressure plate, crossmember, shifter, slave/master cylinders, all bolts
Old Feb 18, 2002 | 07:28 PM
1988roc's Avatar
You will also need trans crossmember, I got mine from Spohn, part# T56-XM
Also if you T56 has the electronic speedo you will need a conversion box. Several companies make them. I got mine from Abbott Enterprises, they call it the Cable X box. Their phone number is 800-643-5973.
I got the 5 speed console plate off of Ebay for $15
You also may need to get a starter, the T56 needs the small nose starter. The junkyards didn't have any here and the dealership wanted $300+ for Corvette one, I wanted the high torque one, so I ended up getting one from Jegs....
The T56 will sit about 1/2 inch higher in the trans tunnel so you will have to modify your driveshaft loop if you have one.
I really enjoy mine now that it's done. It was expensive but worth it!
Old Feb 20, 2002 | 06:21 AM
jimbuck's Avatar
Here is the infor that I used for my swap. I think most of the part numbers are correct.
Item Part No Quanity Each Cost
Master/Slave 12557509 1 $86.25 $86.25
Roller Pilot Bearing 14061685 1 $8.11 $8.11
TO Bearing Retainer 10111569 1 $3.14 $3.14
Shifter Connector 12101857 1 $11.09 $11.09
Speedo Connector 12101899 1 $10.65 $10.65
BU Lamp Connector 12085485 1 $10.73 $10.73
Flywheel Cover 10241153 1 $4.35 $4.35
Flywheel Bolts 12337973 4 $1.28 $5.12
Clutch Cover Bolts 10079898 6 $1.70 $10.20
Bellhousing bolts 10198997 6 $0.40 $2.40
Flywheel Cover Bolts 12337828 6 $0.36 $2.16
U Clamp (Nuts discontinued) 14076942 1 $3.17 $3.17
Cat hanger (5SP Dual Cat) 10026085 1 $10.01 $10.01
Stock Pressure Plate 10232737 1 $105.57 $105.57
Stock Clutch Disc 10232736 1 $98.67 $98.67
Lower Shift/Heat Boot (4th Gen) 10267518 1 $19.47 $19.47
Console Boot Assembly 10201226 1 $- $-
Console Cover 10201225 1 $- $-
TO Bearing 15613306 1 $31.91 $31.91
Pedals Dave Zug 1 $25.00 $25.00
Transmission & Flywheel Oak Hill 1 $915.00 $915.00
Trans Mount ENS-3-1108R Summit 1 $20.95 $20.95
Shifter B&M Ripper BMM-45052 Summit 1 $164.95 $164.95
Console Cover and Boot Dan 1 $25.00 $25.00
Xmember Spohn 1 $100.00 $100.00
Digital Dakota Box (SGI-5) Dakota Digital 1 $79.95 $79.95
Trans Fluid Honda 5 $4.94 $24.70
Clutch Alignment Tool PEPBOYS 1 $3.00 $3.00
Loctite Red PEPBOYS 1 $3.00 $3.00
Loctite Blue PEPBOYS 1 $3.00 $3.00
White Grease PEPBOYS 1 $2.00 $2.00
Total $1,789.55
Sources
Dal 1-800-362-9494 Parts
Larry 1-504-464-4005 Trans
Cars of Maryland 1-410-285-8977 Trans
Bruce Auto 1-800-552-3728 Trans
Oakhill 1-800-553-7110 Trans
Summit 1-800-230-3030 Shifter
Dakota Digital (1-800-593-4160) Speedo Interface
Spohn (1-717-335-3356) Xmember
Koons (301-899-0080) Cust #37979 Parts
Jim Buckingham
Old Feb 20, 2002 | 06:22 AM
jimbuck's Avatar
email me at jjabuck@msn.com and I can send the spread sheet, will be easier to read.
Jim Buckingham
E Rod
Aug 28, 2015 05:17 AM
theshackle
Aug 22, 2015 06:52 PM
Hello, Michael
Aug 20, 2015 03:19 PM
jharrison5
Aug 19, 2015 05:53 PM
355sbcTPI
Aug 19, 2015 04:38 PM
