Just bought a 3.73 ring and pinion gear...
Old Feb 19, 2002 | 07:13 PM
camaroman305's Avatar
What else do i need to fit it in my 92 camaro with the old stock housing?
Old Feb 20, 2002 | 06:19 PM
vjo90RS8's Avatar
Car: 2002 Z28
installation kit (seals, gaskets, etc.)
Old Feb 21, 2002 | 11:01 PM
wiesman's Avatar
Speedometer gears - GM #8642620 and GM 25513052. I just oredered 3.73s myself. I didn't install them yet. But those are the speedo gears I ordered. They cost 10 bucks. If you are doing it yourself as I am you will need tools. Dial indicator and stand, ft/lbs torque wrench, in/lbs torque wrench, micrometer, and the usual wrenchs. Also if you have some miles or abuse on the rearend you will most likely need to replace the bearings. If the rear makes any noise now plan on bearings for sure. Good luck.
hectre13
Dec 11, 2023 08:14 AM
lt1z350
Sep 29, 2015 01:50 PM
86IROC112
Sep 7, 2015 01:37 PM
pimprs
Aug 24, 2015 11:20 PM
johanlindgren
Aug 16, 2015 12:16 AM
