can I convert to 350?
Old Feb 22, 2002 | 11:13 PM
MoDiPhYd's Avatar
can I convert to a 350 instead of a 700r4? since they supposedly are stronger and are cheaper? will it bolt right in? or will I have to do mad mods?
Old Feb 24, 2002 | 08:15 AM
Bob86ZZ4's Avatar
I am in the process of converting to a th400. I am told that it is a no brainer. They bolt to the block the same. I think the th350/400 may be a bit shorter than a 700r4 so you may need to lengthen your driveshaft. Or else get a Gear Vendors overdrive and shorten it like I am doing. Then you will have 6 speeds to choose from. Very expensive tho! I think in a f-body you may have to use a modified cross member to support the tail of the tranny. After breaking 2 700r4's I say "go for the th400." Okay, that said, now see how many people will say just get a well built 700r4. That's what's nice about living in America. We can all have our opinions and spend our money the way we want to.
Old Feb 24, 2002 | 10:01 AM
ede's Avatar
ede
a th700r4 is a th400 w/od so it'll bolt right up. a th350 w/ 9" tail housing is same size and direct bolt in. use a b&m kit for the torque arm or a aftermarket torque arm to relocate it to the floor pan
1992 Trans Am
May 10, 2023 07:19 PM
okfoz
Convertibles
83
Oct 29, 2018 11:18 PM
theshackle
Mar 5, 2017 06:37 PM
Eric-86sc
Aug 24, 2015 09:01 PM
gwade12
Aug 8, 2015 08:17 AM
