What rpm's will I cross the line at with 4.10 gears with 700R4?
Old Feb 23, 2002 | 09:18 PM
southerniroc's Avatar
I have 3.27's now, but they aren't low enough to get me into my power band quick off the line. Would 4.10's be to much gear or should I just go with the 3.70's. I don't drive the car everyday so gas milage isn't to important. If you have them or have had them what did you think about them?
Old Feb 23, 2002 | 10:04 PM
82camaro's Avatar
Car: 82 camaro SC
Need more info, what tire size are you running and/or rpm you currently cross the finish line at. More than likely 4.10's will be too deep to launch with, unless you are running a really tall tire--since you have the 700R4.
Old Feb 24, 2002 | 12:36 AM
I am running 245/50/16 Nitto Drag radial. I cross the line at 5000 rpm and I have my rev limiter set at 7000, but I don't rev past 6500. If ya need more info let me know.
Old Feb 24, 2002 | 10:27 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Those are really short tires, 25.6". With the 700R4's deep first gear I'd say don't go any more than the 3.70 gears unless you get a taller tire.
When I had my SBC, 3.27 gears, 26" tall tires and TH350, I was shifting at 6600 and crossing the finish line at around 5000. I was also running high 11's. 3.90 gears for me would have been perfect but the next season I went to 28" tall tires and 4.10 gears and crossed the finish line just as the shift light came on.
1984HO
Mar 19, 2021 11:59 AM
jklein337
Sep 19, 2018 06:23 PM
Reddeath210
Oct 6, 2015 08:20 AM
hokis
Aug 9, 2015 03:57 PM
