Quickie ?'s on T5 Swap
Old Feb 23, 2002 | 12:37 PM
Patrick007's Avatar
Doing the swap pretty soon.... have a parts car.... can i keep the flywheel that came outta the 700R4 car? Also, do u guys recommend a Centerforce clutch? Or will a stock replacement suit my needs just fine. Mods in the sig....not a ton of power.... so do i really need a nasty clutch?
Patrick DeGrosse Jr.
Old Feb 23, 2002 | 02:51 PM
bhaas's Avatar
That's not a flywheel for the 700R4, it's a flex plate. Won't work. Your gonna need a flywheel. But if you have a complete parts car with the T5 still in it. You should be able to use that flywheel. Make sure you get the flywheel turned first. Get the Centerforce. It's a good clutch. That's what I got. What year is your parts car? If it's 1985 and before your gonna need a flywheel for a one piece rear main.
Brad...
Old Feb 23, 2002 | 05:26 PM
Patrick007's Avatar
Okay that's what i thought.... i didn't know the exact difference between flywheel/flexplate. Anyway, I don't know the year of the parts car. The car is owned by a guy I know and its been sitting in his yard .. forever... so basically he said I can take whatever I want off of it. I guess i'll have to find that out before I start the project. How much do the centerforce's run? Hopefully their not tooo expensive.. but if you say they're that good.. then I'll go with it. Also, while I have the tranny out.. are there any other items I should replace? I'm def. putting in a poly tranny mount but are there any other things I should replace? Thnx again
Old Feb 23, 2002 | 09:04 PM
bhaas's Avatar
I bought the Centerforce Dual Friction clutch, it was $300. Make sure that parts car isn't a V6. If it is, forget about it. Won't fit.
I have a T5 setup. I just pulled it out of my car about an hour ago. I'm pulling the motor and putting new heads and more stuff on it then going back to the TH350 for racing. Since my flywheel won't work on your car I'll sell it for $500 then you'll just have to get a flywheel. I have everything you need for the swap.
Brad...
Old Feb 24, 2002 | 07:07 PM
Patrick007's Avatar
If you could e-mail me with more info that woudl be great. Is that a WC T-5? Mileage on car, good shape? etc... Thnx alot..
Xstasy007@aol.com
Old Feb 24, 2002 | 10:38 PM
pimpintheRS's Avatar
if he doesnt take it i would like info on the tranny also at yodaddysays1@aol.com yes it is my real e-mail account..
trigger GTA
Convertibles
Sep 15, 2012 09:13 AM
MitcherNeaf
Oct 8, 2009 08:02 AM
shr00m
Sep 5, 2005 03:11 PM
92 Red Firebird
OLD Third Gen Nationals
Jun 19, 2003 07:29 AM
tpi_roc
Jan 17, 2002 04:47 PM
