aluminum driveshaft needs to be longer?
I am swapping to a TH-350 on my car and I am working out the driveshaft issues. Is it possiable to make an aluminum driveshaft longer or would I need to find a steel driveshaft and then have it made longer?
I also was wondering if if the aluminum driveshaft would be fine for about 600hp and 700fpt.
The problem is this, no driveshaft can be made longer. You have three options.
1. Get a custom made driveshaft of the right length.
2. Get a driveshaft that is too long and have it shortened.
3. You might get lucky and find one of the right length already available.
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
You need to get a drive-shaft from and 82 camaro with and automatics tranny. They can with the th-200c which is the same length as a th-350.
Originally posted by poncho9789
I have seen steel driveshafts leighthened with no problem. I want to know if it can be done safely with aluminum.
Weld a piece of tube onto it?
I'd like to know.
Re: aluminum driveshaft needs to be longer?
Why not buy one of the proper length? :sillylol:
Pac J
May 17, 2020 10:44 AM
gixxer92
May 18, 2017 11:20 AM
[CA] 700R4 trans & parts
6998poncho
Sep 25, 2015 02:56 PM
