couple of questions about borg warner rears
Old Feb 25, 2002 | 03:13 PM
heavy_chevy29's Avatar
Car: 84 camaro Z28
Engine: 434sbc
Transmission: powerglide
Axle/Gears: moser 9" with 411 posi
i have a couple of questions about borg warner rears.
1. are they all 9bolt rears?
2. how do i know if i have one(if it is not 9 bolt)?
another question is: what is all that crap on my posi unit? i took the cover off today and there are these two things on the one side of the posi( the bigger side you look in). one is like a little circle(looks amost like a clutch). the other thing is right next to it. it looks just like a peice of metal. please help if you know about this. thanks.
Old Feb 25, 2002 | 05:59 PM
Momar's Avatar
I dont know that much, but all borg warner rears are 9 bolts. The 10 bolts do have a clutch style posi so that may be what you are seeing, but someone else will have to answer that for sure.
Ben
Old Feb 25, 2002 | 07:35 PM
CODY BEHNKE's Avatar
Borg Warners are stamped " Borg Warner " and all have the rubber cap filler
Old Feb 25, 2002 | 09:54 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Don't forget, the Borg-Warner resrs for thirdgens are 9-bolts! THat means 9 bolts in the cover and 9 bolts in the ring gear!
Old Feb 25, 2002 | 09:57 PM
Momar's Avatar
Actually if I recall correctly people refer to them as 9 bolts but they only actually have 8 ring gear bolts. I have not counted but I think I remember that being discussed.
Ben
Old Feb 26, 2002 | 10:54 AM
99Hawk120's Avatar
Car: 1999 Pontiac T/A Firehawk
Engine: ***'s Engine
No one has ever adequately explained whether the "N-bolt" nomenclature comes from the number of bolts on the ring gear or the number of bolts on the rear cover.
10-bolts have 10 on both (at least the 7.5/7.625 ones do). I have never opened a 9-bolt so I'm not certain about those.
Old Feb 26, 2002 | 12:38 PM
Momar's Avatar
I dont know but doesnt the 12 bolt have 14 cover bolts or something? Dont quote me on that one, I am asking. I think someone said something like that. Either it had 14 ring gear bolts or cover bolts. That or either I just got a couple of conversations totally mixed up.
Old Feb 26, 2002 | 12:42 PM
99Hawk120's Avatar
Well, I'm looking at a picture of a 12-bolt gasket and it has 12 bolt holes.
GM does have a 14-bolt rear, you know. And according to my sources, both versions (9.5" and 10.5") have 14 bolts in the cover and 12 in the ring gear.
Old Feb 26, 2002 | 12:46 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
Borg Warner 9 bolt rears have 9 bolts on the cover and 8 bolts on the ring gear.
Miles
www.9bolt.com
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Sep 17, 2020 08:26 AM
ezobens
Aug 19, 2015 10:29 PM
jharrison5
Aug 19, 2015 05:53 PM
redmaroz
Aug 16, 2015 11:40 PM
