MTV Down Valve? with a pic!
Old Feb 25, 2002 | 11:58 PM
Low C1500's Avatar
Car: 89 Shortbox
Engine: 350 Vortec
I purchased my 700r4 tranny and it already had a stage to shift kit, but recently it started shifting at very low rpms. I changed the TV cable and adjusted it right, but that made no diference. So I pulled the valve body apart to see if any valves were stuck, none were but the MTV valve didn't have a sping in it. I was wondering if the spring gets removed with a shift kit? or if the sping should be there, also the tranny doens't kick down unless you do it manually.
Old Feb 26, 2002 | 03:37 AM
ingar, norway's Avatar
the TCIŽ 376500 kit removes the M.T.V. Up spring. They have a document for the kit at www.tciauto.com
(The MTV Up / Down valves are swapped on the Transonline picture you posted)
Old Feb 26, 2002 | 01:16 PM
JPiroc87's Avatar
The B&M Transpak kit also removes the spring.
The installation instruction can be downloaded from here:
http://www.bmracing.com/noflash/dwnl...dex.html<br /> There might be some problem in the governor, if the TV valve seems to work OK and the fluid level was correct.
Magman
Sep 12, 2015 10:43 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
1985chevydude
Aug 20, 2015 12:29 AM
cstrobel65
Aug 15, 2015 10:19 AM
Street Lethal
Aug 12, 2015 11:33 AM
