turbo 400!!!!!!!!!
Old Feb 27, 2002 | 06:25 PM
1991tealRSt-topGuy's Avatar
Car: 1991 Corvette Coupe
Transmission: 700R4/4L60 same trans different name
turbo 400!!!!!!!!!
hey folks
i was talking to one of my friends and he said he can get me a turbo 400 already rebuilt for $200
he said its out of a truck
would i need to get a different tailshaft for it
or is it the same size as a 700R4???
and what about the speedo drive cable
what kinda gear would i need to get for that to work?
i know i would also have to get the torque arm mounting kit from jegs..............
Old Feb 27, 2002 | 09:03 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: turbo 400!!!!!!!!!
hey folks
Yes. Trucks usually have a bolt on tailshaft yoke. You'll need a slip yoke for a TH400. The shaft diameter is larger so 700R4, TH350 etc yokes won't fit. Since the tranny is longer, you'll need a custom made driveshaft as well.
If yours is cable drive then you just screw your cable onto it. You may need an adaptor to get the right gearing so your speedo is accurate.
The kit includes a mount for the torque arm, new cross member (TH400 sits back farther), detend switch etc.
Hotrodboba400
Dec 10, 2019 07:07 PM
cheesehomer
Dec 31, 2015 08:48 AM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
bjpotter
Oct 4, 2015 07:48 PM
