Does this damage the 700R4?
Old Feb 28, 2002 | 02:45 PM
F0xBody50's Avatar
Guys-
My car is an A4 w/ 94,000 original miles on it...
Gear Box reads: [P] [R][N][OD][D][2][1]
Sometimes when I cruise around town, I'll put the car in [2], so that the car stays in the 2000-3000 RPM range when I do 30-35mph... and when I decelerate (let my foot off the gas) the Flowmasters will crackle and pop (I love that sound!)... is it hard on the engine / tranny to be going around at those RPMs?
Usually I drive around in [D], but being a 305, I don't get the popping / crackling sound unless I can get the motor near 3000 RPM...
Additionally, a friend of mine told me I can manually downshift from [2] > [1] to slow the car down, and get the popping and crackling sound... and it makes the transmission slow the car down... is this ok? Does it cause additional wear on the tranny?
-ONE
Old Feb 28, 2002 | 02:50 PM
SoCo80p's Avatar
no it wont damage the trans, its ment to do that trans brakeing for when your on hills and things like that.
Old Feb 28, 2002 | 06:18 PM
F0xBody50's Avatar
Cool.. what about driving around at 2500-3000 RPM, is that rough on the engine?
-ONE
Old Feb 28, 2002 | 06:54 PM
SoCo80p's Avatar
well it puts more strain on the engine, its not exactly the best thing to do but you can do it
Old Mar 1, 2002 | 09:10 AM
irocaz28's Avatar
I have an 88 iroc with 5.7 and a 700r4. I drive around shifting gears left and right. Ive been doin this for awhile now and i have seen no problems at all. the engine has over 116000 miles on it too. I use the trans for braking also. I love hearing the engine roar in 2nd gear too. Especially when u get on it until 40 mph or so and then get off it. OH BOY THAT SOUNDS GREAT!!!!!!!!!
Old Mar 1, 2002 | 02:06 PM
Mark A Shields's Avatar
Car: 99 Formula
Axle/Gears: 342
I'm not positive, but I thought transfixleo said, that manually shifting will put some strain on the tranny due to the line pressure or something I believe, in D is when it's at correct line pressure. Maybe he can clear some things up.
Old Mar 1, 2002 | 02:45 PM
F0xBody50's Avatar
Yeah!!
Man, when I get it up to like 2500 RPMs+ and let off the gas... the sound is AWESOME as the engine comes down...
I just don't want to do it too often if it wears the tranny down...
-ONE
Old Mar 2, 2002 | 12:36 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
If you're in a higher gear and you downshift. With the throttle closed, TV pressure is at minimum and so the downshift is soft with lots of slippage.
no green
Jan 9, 2016 09:22 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
TheCardinal
Interior Parts Wanted
Oct 9, 2015 09:43 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
6998poncho
Sep 25, 2015 02:56 PM
