700-r4 on a 72 350 block??
Old Mar 4, 2002 | 10:11 AM
fattie92's Avatar
will the 700-r4 bolt right up to a 72 vette 350 block? if not, what will i need?
Old Mar 4, 2002 | 05:02 PM
Jay 727's Avatar
Yes it'll bolt right up. Be sure the throttle lever geometry is correct, most aftermarket carbs need some tweaking or a special bracket.
Old Mar 4, 2002 | 05:10 PM
fattie92's Avatar
its not an after market carb, im using the stock Q jet
Old Mar 4, 2002 | 05:15 PM
Jay 727's Avatar
It may still need some correction with a 700R4. If the shifts are really early and soft don't drive it even a mile, check the geometry.
My '84 had an electronic q-jet with a 700R4 so you may be alright. I've heard of people having this problem.
Old Mar 4, 2002 | 05:17 PM
fattie92's Avatar
yeah its a computer contorled qjet,, its all in the ecm. so i dont need a OD kick down
Old Mar 4, 2002 | 08:58 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Umm, all 700R4's need a detent cable, it controls all the shift points. It needs to know how much throttle the car is getting to make a certain shift. So, YES, your tranny will need a "OD kickdown cable" for it to work right.
Old Mar 4, 2002 | 09:01 PM
fattie92's Avatar
hmmmm...never heard that before.....so then i can just use the same cable thats there? please give me some more info on this
Old Mar 4, 2002 | 09:08 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Yes, you use the cable that came with the tranny. But you still need to check the geometry of the cable. What that means is, the cable is supposed to be a certain disance from the throttle lever, at closed throttle, and needs to open a certain distance also. I hope someone else can elaborate on this for me, or you can do a search on the board, name it "TV CABLE" and you will find what I'm talking about. It's very crucial that you get this right.
Trust me I've roasted a tranny because of this.
Old Mar 4, 2002 | 09:12 PM
fattie92's Avatar
why would this get out of wack if im not messing with the tranny or the carb?? i found it in me "Haynes Repair Maunal",,maybe that will hepl me
Old Mar 4, 2002 | 09:17 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Wait, maybe I'm misunderstanding, but are you swapping motors?
Are you using same intake as before? Whats all going to be changed?
Old Mar 4, 2002 | 10:07 PM
fattie92's Avatar
ok im putting a 350 in place of my 305. everything motor wise is getting swapped except the carb and tranny.... new block, new heads, new intake, cam, crank...blah blah blah.
Old Mar 4, 2002 | 10:19 PM
StngKlr's Avatar
Car: 89 RS
Transmission: TH350
Ok, well you still need to use the TV cable, and since you are using a totally different motor, meaning intake and such, then the geometry can go off line, so just in case I would check it out to be safe. If you used to use the cable, then you still need to.
Hey, by the way what heads are you using on that. I think the last 3 digits on mine are 882, which means 350 or 400 heads.
Just wanted to see if anyone knows anything about these.
Later,
Rick
Old Mar 4, 2002 | 10:21 PM
fattie92's Avatar
i dont know, some guy is building it for me. Hes putting on bigger heads and all this crap, bored out .040 over pushing around 320HP.. ok well make sure to pay close attention to the TV cable! thanks for the insight guys!
Old Mar 5, 2002 | 04:04 AM
ingar, norway's Avatar
Can anyone tell the correct pull-lengt for the TV cable? I measured a 1987 TPI to be 1.34".
At http://www.sallee-chevrolet.com/Chev...tallation.html they say that the TV spring should be different in a TPI and carb application. If this is correct, why?
(The TransGo kit doesn't seem to care about if the car has carb or TPI)
Jake_92RS
Jan 28, 2020 10:37 PM
theshackle
Mar 5, 2017 06:37 PM
Reborn756
Sep 4, 2015 03:42 AM
Eric-86sc
Aug 24, 2015 09:01 PM
BBSDesigns
Aug 11, 2015 07:39 PM
