94 z28 Camaro ring and pinion Fit in 91 Rs
Old Mar 6, 2002 | 05:28 PM
Collins91RS's Avatar
Does anybody know if the ring and pinion for a 94 Z28 6-speed will fit in a 91 RS rearend it has the 2.73 i think the other ones are 3.42's
Old Mar 6, 2002 | 06:26 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
No. They are the right size, but they need to go on a 3-series carrier, and the one you have with 2.73 gears is a 2-series. The gears will have about an extra ¼" of space between them, which is kind of huge when it's supposed to be .008" or so.
You could get the SLP takeoff posi for $100 bucks, then it would all work.
Old Mar 6, 2002 | 06:33 PM
what would the SLP takeoff posi do ?
Old Mar 6, 2002 | 06:39 PM
Kenwood's Avatar
Car: 1987 GTA
Engine: PT88 Turbo DART 406
Transmission: th400
Axle/Gears: 9" ford
It would be the 3 series carrier therefore work with the gear setup..
Kenwood
ICON MOTORSPORTS
Old Mar 6, 2002 | 06:46 PM
Do you know the produst number?
also thanks i really appreciate your help
Old Mar 6, 2002 | 06:53 PM
Kenwood's Avatar
Car: 1987 GTA
Transmission: th400
Axle/Gears: 9" ford
I dont know the part number off of the top of my head But its EASY..... They are TAKEOFFS from SLP.....BASically when the 4thgen comes from the GM PLLANT TO SLP to be turned into say a camaro SS......SLP takes out that Unit....But the idea is that since you are trying to run 4th gen gears you get a perfect match by bolting it up to the 4th gen takeoff diff....
You get a deal in that basically you get a brand new unit....GM assembles it...drive the car like 4 minutes up the road to slp...They take it out...So its about as NEW of a used part as you can get...
Hope this makes sense... SLP website lists them on their products page...
Kenwood
ICON Motorsports
1987 Vortech Blown GTA
1985 Vette
2000 TRD GTS
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
CarGuyDennis
137
Dec 6, 2016 11:02 PM
hectre13
Aug 26, 2015 08:17 AM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
