What is the best # of Clutch's to have? w/n
Old Mar 9, 2002 | 05:04 PM
Timbo89GTA's Avatar
Car: 89 Trans Am GTA
Engine: 383 TPI
Axle/Gears: 3:27
This is what im finding Im looking for a new tranny. Any info would be great thanks timbo.
8 Borg Warner Hi-Energy clutches along with
Kolene steels used in the 3-4 clutch pack
9 count Red Eagle clutch pack with Kolene steels for the 3-4 clutch
10 stack 3/4 clutch pack
Old Mar 9, 2002 | 05:32 PM
Pro Built Automatics's Avatar
You can use 8 .080 BW hi-Energy's with 7 .060 Kolene steels. I have found this the best for Street/Strip. If you plan on road racing, then 7 .080 BW hi-Energy's with 6 .080 Kolenes steels. This setup will handle more heat due to the cycling of the 2-4 band & 3-4 clutches. I do not like the thin Red Alto clutches , they do not retain enough oil for heat dissipation.
Old Mar 9, 2002 | 05:52 PM
transfixleo's Avatar
One more opinion on this. As long as you do not have a killer engine I like to use the 4L60E 3-4 pack with it's ridgid Pressure and Apply Plates and thick (.106") steels along with the High Energy B/W Frictions. They are really durable and along with the TransGo SK or Reprogramming Kit will stand up for a long time. If you get into higher power numbers then extra High Energy B/W Fric's are the way to go.
Old Mar 9, 2002 | 10:37 PM
graebz28's Avatar
Car: 83 Z28
Engine: 406
Axle/Gears: 9" with 4.10s
There is so much knowledge on this board it is sick
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
meeklay812
Oct 1, 2015 03:46 PM
mfp189
Sep 27, 2015 09:25 AM
Night rider327
Sep 2, 2015 04:18 AM
