changing 2.73 to 3.73
Old Mar 12, 2002 | 10:14 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I have a 89 rs posi rear with 2.73 gears and I am wanting to go to the 3.73 gears. Will I have any problem with the posi unit.
I would like to install them myself with same carrier and housing, but I dont have the guages. I though about just putting the shims back as the were, but am afraid of messing the gears up.
What is a good price to pay to have them installed. I can remove the rear If that is cheaper and easyer.
Old Mar 13, 2002 | 09:34 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I know someone has done this swap. Did it make alot of sotp difference?
Old Mar 13, 2002 | 12:38 PM
Momar's Avatar
You will need a new posi. If you have 28 spline axles you can buy one for around 100 from www.slponline.com Oh, and it should make a heck of a sotp difference from 2.73 to 3.73.
Old Mar 13, 2002 | 11:58 PM
IROC-ZWV's Avatar
i have a high gear alo, and im happy with it. the lower you go the worse gas milage you get right?
Old Mar 14, 2002 | 07:19 AM
Momar's Avatar
Yes, the lower (higher numerically) you go the better accleration and less gas mileage. From what I have heard most people dont loose a ton on gas mileage from a gear swap, but that is a large difference so you might loose a bit on mileage.
Ben
Old Mar 14, 2002 | 08:30 AM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Why Would I have to change to a new posi. Cant I get a gear from summit to fit my posi. It says for a 3.08 and numerically lower carrier. This should work. The posi and axels are in the same rear.
Old Mar 14, 2002 | 09:53 AM
Momar's Avatar
Yes, your right. If you got the stock style gear you would need a new posi, but they make gears that you can use your posi with. I have a 9 bolt and they dont make gears like that for it so I just didnt think about that.
Ben
hectre13
Dec 11, 2023 08:14 AM
Orr89RocZ
Apr 25, 2016 08:28 AM
Eric2ndGen
Nov 5, 2015 01:51 PM
Warlocksirix
Sep 3, 2015 12:26 PM
Regal105
Aug 23, 2015 03:45 PM
