91 rs rearend
Old Mar 20, 2002 | 03:37 AM
83Blackwidowz28's Avatar
Car: '91 Rs
Engine: 3.1 MPFI V6
Transmission: 700R4 B&M Shift Kit 2300-2500 stall 9" tq
Axle/Gears: stock 10bolt 3.23 gears
91 rs rearend
I gotta 91 rs v6, I heard from someone that it comes with a limited slip diff.
But when i power brake i only get one tire mark and the tires are brand new. Does this model come with a posi are not?
I've also heard around that there is a sports package rs v6 whats the diff. than a regular one?
Thanx
Old Mar 20, 2002 | 07:27 AM
BigRuss's Avatar
I don't think braking will give any indication of whether it's posi or not. Locking the brakes is supposed to lock up the rear wheels anyway, so the differential doesn't matter. Might be just a brake system problem.
Best way, by far, to tell if it's posi is to pull the cover off (probably needs a fluid change anyway). Spider gears is open-differential, clutches is posi. I say pull the cover because even if it is posi, the clutches could be worn out and it'll act like an open-differential no matter what other tests you do.
I don't know about any sports package for the v6.
Old Mar 20, 2002 | 08:19 AM
TopJimmy92rs's Avatar
brake torque it on a good road with no gravel on it and if you get 2 black marks you will find out its posi if no you have limited slip. if you have a manuel trans you have 3042 gears and if its an automatic then you probably have 323's but i don't think you have posi.
Old Mar 20, 2002 | 11:18 AM
Car: '91 Rs
Engine: 3.1 MPFI V6
its an auto, it does have 3:23's. i'll open her up this weekend see what i got
If it is worn were can i find one for a good price??
thanx
Old Mar 20, 2002 | 12:56 PM
TPortFormula's Avatar
Car: 1991 Pontiac Firebird Formula
Transmission: a crappie 700-R4
well, if you have 3.23's, and if the posi is worn, you can get a torsion diff posi from www.slponline.com. if you never had posi in the first place, but still have 3.23's, then you can still get this. it will work for 3.23's and up. when you take off your cover, make sure you have 3.23's by looking at the ratio on the ring gear. it should say 42:13. if its anything else, use a calculator to check.
Old Mar 20, 2002 | 02:40 PM
Car: '91 Rs
Engine: 3.1 MPFI V6
thanx for the info :lala:
Old Mar 20, 2002 | 08:47 PM
jamesbern's Avatar
The only way to know for sure is to pull the cover. My RS spun both tires since I've had it and I always thought it was limited slip until I pulled the cover to install gears. I have talked to a few people who have had the same experience. Good luck!!
UltRoadWarrior9
Apr 28, 2020 10:39 PM
Nervous2
LSX and LTX Parts
Mar 10, 2016 09:49 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
86White_T/A305
Aug 17, 2015 12:16 AM
