93-02 rear on a 89 camaro
Old Mar 22, 2002 | 01:39 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
what would i need to put this 93-02 rear on my camaro. it already has 3.42's and disc's. and would my wheels work right now on them, and my future wheels which are 17x9's.
Old Mar 23, 2002 | 12:03 AM
u r sofa king we tah did's Avatar
your wheels will work. about the only thing you will need to do is bend a new brake line since the rear end is a bit wider. its very simple to do. i have a 3.42 posi rear end out of a 4th gen in my car, it bolts right up with no modifications.
Old Mar 24, 2002 | 02:01 AM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
so master cylinder and proportionting vavle will be the same. just bolt in the new rear and attach the brake lines. will this work for a 93 and up camaro and firebird rear.
Old Mar 24, 2002 | 04:06 AM
Zepher's Avatar
Car: 86 Trans Am, 88 Formula
Engine: 95LT4, 305TPI
Transmission: T56, T5
I've got the rear off of a 95 Formula. Bolted right up, even the brake lines bolted to the calipers. Just need to get the E-brake cables fastened to the car.
Old Mar 24, 2002 | 12:09 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
how do i do that
Old Mar 24, 2002 | 12:57 PM
if you have rear drums right now you will need to change your prop. valve
Old Mar 24, 2002 | 07:47 PM
TKD89RS's Avatar
Car: 1995
Engine: 5.7
my prop valve has both lines on the bottom. do i still need to change it.
Frozer!!!
Jan 19, 2024 04:55 PM
hectre13
Dec 11, 2023 08:14 AM
Vintageracer
Jan 10, 2020 05:33 PM
Mutillator
Exterior Parts for Sale
Oct 1, 2015 06:05 PM
THABADGUY
Brakes
Aug 11, 2015 03:43 AM
