Keeps leaking gear oil...HELP!
Old Mar 22, 2002 | 02:39 PM
BlackBird305's Avatar
i wanted to change my gear oil and posi fluid so i drained it all then cleaned everything up...i then ran a bead of perma-tex around the rear and put the cover back on...it was squeezing gear oil out the bottom of the diff cover, so i drained it all again and did the same thing but this time i let the car sit overnight to let the tex cure better in hopes it wouldn't leak...well it still does...what am i doing wrong?...help me out, thanks guys
Old Mar 22, 2002 | 03:27 PM
BigRuss's Avatar
Re: Keeps leaking gear oil...HELP!
Did you take a razor to it and remove ALL traces of old gasket? Plus, did you put on a new gasket? If so, then try cleaning up the surfaces with degreaser first, then coat the gasket with silicone and press it to the housing, wait about 5 minutes then press the cover on. Torque the bolts to 30 ft lbs and see what happens.
I've only pulled the cover and replaced it once, but didn't have any problems with leaks...
Old Mar 22, 2002 | 07:51 PM
Ricktpi's Avatar
Car: 1987 Camaro Z-28
Engine: 6.3L Victor EFI
Transmission: Tremec TKO 600
Axle/Gears: Moser 9"/4.11 Trac-Lok
If you are not using a gasket. That could be your problem. Using RTV alone will work, but you have to use it on a clean surface. Its best to use a GM gasket & either Permatex Black RTV or GM's GMS. Your leak is probably coming around the threads of the bolts at the bottom.
jklein337
Sep 19, 2018 06:23 PM
Matt86IROC
Sep 7, 2015 06:30 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
mizz0313
Aug 12, 2015 06:45 AM
