Spider Gears and mini-spool
Old Mar 26, 2002 | 01:18 PM
woody86's Avatar
I have an 84 with a stock rear. The spider gears are shot. I have a mini-spool but it says that it can only be installed in an "open" rear end. The question I have is........does a posi rear have spider gears, or only an open rear? Thanks in advance
Old Mar 26, 2002 | 06:07 PM
woody86's Avatar
a little help please!
Old Mar 26, 2002 | 11:37 PM
88 427 Camaro's Avatar
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
For a 7.5, 7.625 and a 7.75 rear, the mini spool requires an open carrier for installation.
Miles
Old Mar 27, 2002 | 06:25 AM
woody86's Avatar
I know that. The question I have is.....does a posi rear have spider gears or just an open rear?
Old Mar 29, 2002 | 10:16 AM
Omega's Avatar
Car: 89 Formula / 09 G8
Engine: LS1 / LS3
Transmission: M6 / M6
Axle/Gears: 3:42 / 3:27
There are several different types of posi units. One uses a cone system with a few springs. Another one has spider type gears with a funky "S" shaped spring. The zexel torsion is a whole other animal that can tell from a mile away. I think that you are asking if you can use this mini spool with your carrier. If you are, you can.. You only have the spider gears with no other springs or gizmo's in the carrier right? If so then you can use your stock carrier with the mini spool.
F-body driver
Mar 6, 2023 11:44 AM
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
