Is this normal?
Old Mar 26, 2002 | 09:21 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Transmission: 700-R4
Is this normal?
I have a fully race prepped 700-r4 and a Super Yank 3500 TC installed in my car. Both are brand new and JUST put in. Well I was under the impression after driving a few fourthgens with aftermarket stall convertors that when shifting the car into gear it's smooth, and the motor won't pull the car till you give it some RPM. But my 700-r4 and with my TC likes to shift HARD from park into gear, and it pulls at idle (idle is about 800 on a modded LT1 motor). Is this typical for 700-r4 and TC combo? I can maybe see that on 4th gens the tranny doesn't shift hard into gear because it's computer controlled. Any thoughts on this?
Old Mar 27, 2002 | 04:14 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
ttt
Old Mar 28, 2002 | 06:54 AM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
ttt
Old Mar 30, 2002 | 04:19 PM
Markolc's Avatar
Car: '87 IROC
Engine: LT1 350
Up
Old Mar 30, 2002 | 07:48 PM
Momar's Avatar
Well, I am no expert but just to give you something and put keep this up top for you: I think that it is very possible that it is just because of newer tranny design that keeps the shifts from park smoother on the fourth gens. I know that the 700r4s with the newer valve body style are supposed to shift out of park smoother than the older ones. As for the torque converter yanks are supposed to be great. From what I have been told higher end torque converters arent supposed to slip to much at low rpms under part throttle, but when you punch it, it the rpms should jump on up there. Hope this helps.
Ben
Old Mar 31, 2002 | 12:17 PM
SSC's Avatar
SSC
Car: 1989 C4
Axle/Gears: 307
Momars right.
I see you car is an 87 but if it's an early 87 it will not have the auxiliary valve body that reduces banging from park to reverse or down to drive. If your car does have an auxiliary valve body it will have a tube over the valve body that runs from the back to the front on the drivers side. If you post the numbers found on the passenger side rear lip I'm sure someone could tell you for sure.
Fanatic1074
Oct 3, 2022 05:57 AM
Linson
Oct 1, 2015 09:50 PM
Giocio
Oct 1, 2015 12:20 PM
dusterbd
Sep 29, 2015 08:40 AM
BWilcox
Sep 20, 2015 12:19 PM
