700R4 Disassembly Help
Old Mar 30, 2002 | 04:24 PM
FJK's Avatar
FJK
My son & I are totally disassembling his 88 GTA 700R4 to find the cause of no 3/4 gear. I'm kind of stuck at this point of disassembly. How is item #680, spring, lo&reverse clutch suport retainer, suppose to be removed. I think this is what I'm trying to remove. At first, it looked like a broken snap ring to me , wedged under the support assembly ( between support & case). One end looks like a snap ring laying flat & the other end looks like a snap ring laying on edge. Any advice or photos would really help. I'm sure I'll have more questions later.
Thanks, FJK
Old Mar 31, 2002 | 08:29 AM
Jay 727's Avatar
I use a wide blade screw driver, put it between the case and snap ring and turn it then grab the snap ring with needle nose pliers and work it out of the case. The other thing you are seeing may be the anti clunk spring, it sticks up a little in this area too, be sure to put it back in during reassembly.
Old Mar 31, 2002 | 09:18 PM
Nordbert's Avatar
Yeah, use a big, flat blade screwdriver with a notch cut into
the side. After you get the blade under the snapring, twist the
screwdriver to hook the snapring in the notch and pull toward you. Work around the case until it is free.
Old Apr 1, 2002 | 03:50 PM
FJK's Avatar
FJK
The part I am talking about is refered to as a spring, not a snap ring. If we are talking about the same thing, do you get the screwdriver under the end that is laying flat, or the end that is laying "on edge"?
Old Apr 1, 2002 | 06:07 PM
Jay 727's Avatar
Who is refering to it as a spring?
It goes between the case lugs and low reverse roller clutch right? It holds it in the case?
Old Apr 1, 2002 | 07:49 PM
FJK's Avatar
FJK
Jay 727:
Yes sir, you are correct about what I am talking about, but the GM service manual refers to it as a spring; specifically item #680, Spring, Transmission (Lo & Reverse Clutch Support Retainer). I didn't name it, I just need further help on how to remove it. Hope you can help. Thanks FJK
Old Apr 1, 2002 | 08:35 PM
FJK's Avatar
FJK
Finally figured this one out for myself. This little device indeed acts as a spring, which applies tension against one of the spline cutouts in the support. To remove the support, use a large scewdriver on the end of the "spring" that is sitting on edge. Compress the spring by pushing the edge end toward the flat end of the spring. IOW, like collapsing a "U". With the tension off the spring, the support slides out. The spring is then merely lying on the bottom of the trans case. Hopes this helps someone.
FJK
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
indygene
Sep 26, 2015 11:21 AM
6998poncho
Sep 25, 2015 02:56 PM
