Choosing torque converter...not that easy
Car: 1988 Medium Orange Metallic IROC
Transmission: 700R4 transgo shift kit
Axle/Gears: 4.10 in box lol
Ive been checking posts...checking sites...
choosing a torque converter is dependent upon peak torque point at a certain rpm...
then you want the converter to be 400-700 rpms under where the engine makes the most power...
how do i determine that without getting my car dynoed?
355...
comp cam 08-300-8
other parts here and there.
what info do i need?
anyone runnin the same cam?
I want a converter better than stock for a daily driven street/strip car.
355...
comp cam 08-300-8
Car: 89 GTA
Engine: 383
Transmission: 4L80E
Axle/Gears: 12 bolt-3.73
http://www.converter.cc/
There is some good info on the website above.
I think the rule of thumb is get the stall 500 rpm below peak torque. Find out where that cam makes peak torque and 500 rpm's below that is where you want to be.
I have a 2400 stall 12" convertor for sale if you want it, but I'd recommend something with at least 2800 stall.
I'm running 3500 stall now, and will probably step-up to a 4200-4400 stall in the summer. Don't be afraid of of anything over 2500 stall, it won't kill you or your mileage, if that's what you care about.
All i care about is beating the other guy...and still get to work.
So comp-cams should be able to give me my peak power points?
if I can take a 3500 you may have to get your new one sooner
:lala:
:lala:
The duration of the cam at .050, the lobe centers, the rear end gear ratio, & the type of driving you do have the most in determining the stall needed/required for your application. Let me know if I can be of help?
Car: 91 firebird,mint
Engine: 305 tbi,lots of work done
Transmission: 700-r4 built by level 10 in nj
Axle/Gears: 3.73, auburn , precision
206/212,112deg,3.73, beat on it usually 2400 at break/2800 at flash is in there now........thoughts pro ?
Pro Built...ill talk to ya tommarow about the converter as well.
i have 2.73s in the rear..thinkin about 3.42s or 3.73s...but I dont want to lose top end...im only toping out at 155-160 mph with the stock rear (auburn posi)
no green
Jan 9, 2016 09:22 PM
