All rearend experts please read!!
Old Apr 3, 2002 | 06:08 PM
iroc420's Avatar
I have a 1987 iroc-z with a 350 TPI. I was wondering if the Iroc has posi. Also what gears did my car come stock with?? Thank you
Old Apr 3, 2002 | 06:34 PM
rdog30's Avatar
Car: 85&95 Trans am
Engine: 85-LT1 95-LT1
Transmission: 4l60e & 4l60e
Axle/Gears: 3.23 & 3.23
Hold your brakes and press down the gas(called a burnout) if it leaves two sets of marks it's posi. Should be posi anyway if it's an iroc. If it has the 9-bolt it cmae with either 3.45 0r 3.23. If 10-bolt should have 3.08,2.77, or 3.42. Probably wrong on the gear options ,but I think I'm close. Check the main page.
Old Apr 3, 2002 | 11:44 PM
88IROCARMY's Avatar
Look up the RPO code in your glove compartment(sometimes helpful) or remove the rear cover( good time to change the fluid ang clean it out).
Old Apr 4, 2002 | 01:50 AM
88_RS&86_Z-28's Avatar
well my 86 z-28 had a 305 in it and it had a posi with 2.73 in it
Old Apr 4, 2002 | 06:49 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
You probably have a 9 bolt with a 3.27 posi.... but possibly only a 2.77.
If it's a 9 bolt, there will be a tag on the back cover that will say the ratio.
How to identify 9 bolts versus 10 bolts. Count the bolts holding on the back cover...
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
WickedBowtie
Members Camaros
Sep 17, 2015 09:13 AM
WickedBowtie
Sep 11, 2015 11:24 PM
carid
Sponsored Vendors
Sep 10, 2015 09:33 AM
