Fourth Gen Drive Shaft ? S
Old Apr 1, 2002 | 04:06 PM
Fastcamaro87's Avatar
I just bought a supposed AAM heavy duty drive shaft. What I need to know is: What year fourth gens have the balancer ring on the transmission end of the drive shaft? And, will the ones with the balancer ring work on a third gen? Also, are the stock drive shafts made out of cast iron or steel? And I am just trying to make sure that this is not the notorious LT1 "VibeShaft". Also what is the difference between the LS1 and LT1 drive shaft? I will post pictures later of the one I have. Any information will be greatly appriciated.
Thanks,
Matt
Old Apr 2, 2002 | 09:07 AM
here is a picture of the factory one and the one i just got.
Old Apr 2, 2002 | 11:42 AM
wow no one can answer my question??
Old Apr 3, 2002 | 12:54 AM
Man, not even a moderator has responded.
Old Apr 3, 2002 | 02:59 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
See if a magnet will stick. If it doesn't, its a good aluminum one. Al LS1 d/s are slightly bigger in diam then the Al 1LE shafts. Aluminum shafts will not be rusty looking either.
Old Apr 4, 2002 | 06:55 AM
Brian Shaughnessy's Avatar
Car: '89 Formula
Engine: 355 TPI
Axle/Gears: 3.70 9 bolt.
Your 'balancer ring' is actually a vibration dampered yoke that is common to a T-56 tranny... those yokes came on steel OR aluminum 4th gen shafts.
That yoke WILL NOT FIT a T-5 properly as it's too ong.
You can swap your old yoke onto the AL shaft you got and be fine.
1992rs/ss
Jan 31, 2025 05:10 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Reddeath210
Oct 6, 2015 08:20 AM
jharrison5
Aug 19, 2015 05:53 PM
transam84
Exterior Parts for Sale
Aug 14, 2015 08:54 PM
