T56 complete parts pricing list
Car: '91 t-top RS; '91 hrdtp Z28
Engine: LO3;383tpi
Transmission: 700r4;very nice 700r4
Axle/Gears: 4.10 zt posi, 3.70 auburn
Hey everybody. I was just putting together a price list for the parts I still needed for my T56 swap, and figured I'd also post it here to give people an idea of how much it costs.
Parts I have:
Tranny (94 Z28) . . $1,400
Bellhousing . ..included w/ tranny
Shifter ...included w/ tranny
Lower console rubber boot . ..included w/ tranny
Slave/master cylinder ..included w/ tranny
Tranny to bellhousing bolts .. .included w/ tranny
Flywheel (resurfaced) .. ..$25
Shifter **** .$10
Shifter handle (short throw) .$45
Shifter plate w/ boot .. .$50
T56 pedal assembly(94 Z28) ..$30
Pressure plate to flywheel bolts included w/ tranny
Total so far . .$1,560
Parts still needed:
Clutch/pressure plate/ throwout bearing .$270
Vehicle Speed Sensor(VSS) .. .. .. .$50
VSS plug .. .. .$20
4 qts auto trans fluid (Dexron III) ..$6
Crossmember and torque arm
w/ front ds safety loop(Spohn) ............$400
Transmission mount (Polyurethane) .$20
Roller Pilot bearing . . $15
One piece rear main seal .....$20
Recalibration Box(Dakota digital SGI-5) $85
Bellhousing to engine bolts $10
Flywheel to crank bolts(6) $6
Total more to buy .$902
Not included is the labor cost of installing the pedals and slave/master cylinder, which will probably run about $160. Trust me, trying to install these pedals is not as easy as some people make it out to be! I'm also not to sure if my starter will work. I currently have an automatic 700r4 ('90 RS). If anybody knows FOR SURE, please let me know.
Parts I have:
Shifter **** .$10
Parts still needed:
VSS plug .. .. .$20
Pretty complete list. I got a mini starter for mine. You can use yours, but have to do a little grinding on the bell housing. Also, with the mini starter, the wires are real tight coming from the battery.
Terrell351
Jun 13, 2021 01:13 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
