Fan relays
Old Apr 23, 2002 | 06:36 AM
86camarodriver's Avatar
Fan relays
Does anyone know where all of the fan relays are for our cars. Ever since I pulled the A/C the freakin fan wont shut off unless I disconnect it and a few people said I needed toground a relay but I have no idea where those are.
David
Old Apr 23, 2002 | 09:24 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Don't listen to those guys. Your relay's fine.
On the hard line you removed from the passenger side's main frame rail, there was a sensor. This is the "high pressure A/C" sensor... well, not sensor, it's a "switch". When the pressure becomes very high in the a/c lines, the switch opens, and the fan kicks on.
So take that connector, and put a jumper wire inside to connect the two pins. Tape it up, and you're good to go.
Side note: Looks like a real easy spot to put a fan switch on, eh?
Old Apr 23, 2002 | 10:22 AM
I saw a hard line attached to the body that runs to the condensor (have not had time to pull the condensor yet) over there but I never disconected anything, I did pull some wires connected to the compressor though. Do I need to pull the condensor and the hard line before I can do what you said?
David
Old Apr 23, 2002 | 03:40 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Well, if you never disconnected anything, then disconnect that sensor on the hard line that's bolted to the passenger side's main frame rail, and connect the two terminals with a jumper. This worked for my a/c, but I have the entire system pulled and disconnected, except for the a/c evaporator against the firewall. (I needed something to plug that heater/evap box hole! I don't really feel like digging in and putting a heater-only box in there; plus, I've never seen one around here.)
Old Apr 23, 2002 | 04:45 PM
Ok I will try that Saturday
Right now I have that hole covered with Duct tape
David
Falcon50
Aug 22, 2020 03:26 PM
sheachopper
Jul 31, 2019 11:27 AM
thunder57
Nov 7, 2015 02:28 PM
Fanatic1074
Oct 2, 2015 03:47 PM
