My Temp Gauge is stuck over 260
Old May 3, 2002 | 09:58 PM
1989RS_Camaro*'s Avatar
The car is not have no problems can anyone help me find the right wire for this gauge like to fix it so it can work again...
Temp Gauge
1989 Camaro RS
Old May 3, 2002 | 10:50 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
The wire for the engine temp gauge is a green one, and can be found at the "Front" of the "driver's side head", right below the lip of the "driver's side valve cover". It'd wind up being behind the a/c compressor. As ya look at the front of the engine from the bumper, the a/c compressor is at the top driver's side of the motor.
Old May 6, 2002 | 07:46 PM
Ratchet's Avatar
I don't think you have an electrical problem with your temperature gauge. Mine did the same thing I turned on the ignition switch and the gauge stuck way over 260. I tapped on the front of the gauge and it fell back where it should have been but after a while it would not return by tapping on the gauge. I ended up drilling 1/16th hole in the gauge face and knocked the needle back down. Then I drilled another hole at the 12:00 o'clock position and left the drill in it now when I turn on the key the gauge pegs out on the drill and returns to normal operating range.
Old May 9, 2002 | 10:26 PM
grimesjm1's Avatar
Ratchet.... That's Awesome! I have the same problem with mine, I'm gonna do that first thing tomorrow!
Old May 17, 2003 | 10:13 PM
rubber_lee's Avatar
stuck needle
My temp needle was stuck and annoyed me for the longest time. I finally took some clear plastic tubing and cut a very small piece and stuck right in there. The needle will hit and bounce right back to normal like it should. The little tube is not noticeable at all and works great.
Bubbajones_ya
Jul 6, 2024 08:32 PM
codeysabatini
Nov 10, 2015 04:07 PM
wisemanz28
Sep 20, 2015 01:26 PM
codeysabatini
Sep 20, 2015 11:36 AM
corey8084
Sep 17, 2015 02:56 PM
