vaccum line confusion
Old May 16, 2003 | 03:06 PM
jmb_o0o's Avatar
Car: 91 rs vert'
Engine: 5.0
I recently got my car back from the mechanic and he claimed he fixed the vaccum hose-the one from the throttle body to the container next to the air intake. Apparently it wasnt connected. Since then my car runs like crap! It shifts HARD at high rpms into second and my moms lumina stomped it at a light at half throttle, I had the to pedal to the floor. Since then i unhooked the line and it runs like it did before. Has this happened to anyone before? Is it absolutely neccessary that that vaccum line be hooked up? I'm confused-jmb
Old May 16, 2003 | 03:57 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Container near the intake? Not sure what piece that is... can you give a better description?
Old May 16, 2003 | 04:03 PM
jmb_o0o's Avatar
Car: 91 rs vert'
Engine: 5.0
ok if you opened the hood, and located the air filter, to the direct left of that, its a tubular black container thing
Old May 16, 2003 | 05:59 PM
CamaroRS385hp's Avatar
Car: 1987 Iroc-Z28
Transmission: auto
TomP, he means this canister:
(finally got the crappy stock airbox out of the car )
Old May 16, 2003 | 07:02 PM
Jurrel's Avatar
Car: 1984 Firebird
Engine: 2.8 Carburated
Transmission: T5 Manual
Ah you all mean the Charcol canastier! Good old EVAP system...what a POS....
Old May 16, 2003 | 10:57 PM
Nixon1's Avatar
Car: 95 E-150 & 07 Kawasaki ZX-6R
Engine: A slow one & a fast one
Transmission: A bad one & a good one
Axle/Gears: A weak one & a chained one
Why in the hell would disconnecting a vacuum hose from the charcoal canister make your car run BETTER....you should be leaking vacuum and running like ***... Have you tried disconnecting the vacuum line and PLUGGING IT instead of leaving it open? See what that does. This doesn't make sense at all though... For it to affect the transmission shift points and firmness even? That's something affected SOLELY by the hydraulic pressure inside the transmission, which is controlled by the TV cable on the throttle blade...the two are in no way connected...
Old May 16, 2003 | 11:40 PM
Ovrclck350's Avatar
Maybe he connected the wrong line to it.
BTW, try resetting your TV cable anyways...it's easy.
Old May 18, 2003 | 12:48 AM
CC_HotRod's Avatar
Car: 1984 Camaro
Engine: V6
Transmission: 700 R4
I don't know if this may help, but there is a filter at the bottom of the charcoal canister and if it is completely clogged this may hinder vaccum. Just a thought.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
Jorlain
Oct 8, 2015 01:57 AM
bubbaz28
Sep 18, 2015 02:09 PM
TBRays98
Sep 6, 2015 05:05 PM
rjcme
Sep 5, 2015 01:23 PM
