stupid transmission :(
Old May 8, 2002 | 07:04 PM
Berlyn0963's Avatar
Car: 91 Camaro RS
Engine: GM PP crate 350
Axle/Gears: 3:42 spooled 10 bolt
TH700R4 turbo auto w/ OD
hey i was backing up in my friends driveway yesterday and it was a very VERY steep grade but the i stopped and put on brakes while i was still in reverse to wait for him to get in the car but i let off the brakes a lil and it started rolling forward> and then it kept going slowly forward and i got scared and slammed on brakes and put in park and put hand brake on to make sure it was not moving anywhere. i look under car where tranny is and it seems normal .
i have never encountered this problem b4 and im extremly worried that my awesome tranny is going to crap out on me and i dont have the money to fix it either at this time
please tell me what is wrong and what to do about it
thanx
Berlyn
Attached Thumbnails stupid transmission  :(-bad-parking-job.jpg
Old May 8, 2002 | 07:39 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
If a hill is steep enough, you can still roll forward while in reverse in an auto tranny. It's normal.
At idle on a hill, the impeller in the torque converter isn't spinning fast enough to spin the turbine which is physically linked to the trans and wheels.
Oh, and if you want to see how torque converters work, go to www.howstuffworks.com
Old May 8, 2002 | 08:00 PM
Joe_L's Avatar
Car: 1995 Z28
Transmission: Built 4L60E
Axle/Gears: 3.23's - Limited Slip
Thats normal.
The trans is designed to hold itself on a normal grade of a hill.
But if you don't think the hill was that steep, check the fluid level it could be down. Other then that your fine.
Old May 8, 2002 | 08:31 PM
fiream's Avatar
Car: 1983 Pontiac Firebird
Engine: 400HP 350
What they said........
Hotrodboba400
Dec 10, 2019 07:07 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
TX-SleeperC5
Sep 24, 2015 03:13 PM
Youngs92
Sep 23, 2015 11:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
