comp cam magnum roller rockers
Old May 17, 2002 | 08:45 AM
redRS92's Avatar
hi guys i just got some comp cam magnum 1.6 roller rockers and was wondering how much hp i might get out of them i did some math and the 1.6 with my stock cam brings it to the crane cam specs for the firebird and the camaro
Old May 17, 2002 | 10:34 AM
KED85's Avatar
ROLLER TIP
or ROLLER ROCKERS (FULL ON)
Roller tip-FITS
Roller Rockers-need work to fit under valve covers.
You'll never get rid of that dead spot from 2500-3500, you'll get more top end breathing. But, ya gotta compensate "cam" with exhaust, ignition & air coming in.
How are your valve springs?
Old May 17, 2002 | 12:48 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, don't just look at "gross lift" when you work in your rockers; cams have different durations for each lobe, and that's what makes camshafts different. Gross lift can vary; lift @ 0.050 is usually the "standard", so ignore gross lift altogether.
Old May 17, 2002 | 01:33 PM
redRS92's Avatar
they are the tips i was just wondering about the the hp gains i might get out of them
Old May 18, 2002 | 11:29 AM
KED85's Avatar
MORE THAN ANYTHING ELSE, you have more stronger RPMS at top end.
It's the seat of pants feel you seek.
Only you will know that answer.
Find yourself a test road.
Do before and after testing.
HP is only a number.
You want increased torque and better, smoother engine breathing entire RPM range.
Let us know how it feels!
No prob on the tip rockers.
You got 1.6?
Simple.
Check motion thru observation of rockers w/o covers.
Turn over engine by hand on crank.
Should could be ok!
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
New2Chevy
Sep 28, 2015 12:35 AM
Stryker412
Sep 7, 2015 09:11 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
