1st gear lockout
Old May 20, 2002 | 04:33 PM
camaro89dude's Avatar
1st gear lockout
Alright guys, another question. This one's a little more down to earth. All the V6 camaro guys i know have the first gear on their 700R4s locked out. I can manually shift into the other gears but not first. Is there a way to bypass this? I bet you get this question all the time, but the guys on the transmission board wouldn't answer
also if anyone wants to buy a front end ground effects piece in pretty good shape, let me know, i got a dark metallic red one with gold racing stripes sitting in my backyard (charleston SC)
thanks
Jason
89RS 2.8
Bosch Platinum plugs
cat. converter removed
leaky pipes for that mad bumblebee sound
wolf front end bra
berlinetta front end
junkyard 700R4 (blew the old one to hell)
nothing special
nothing fast
need quarter panel ground effects
Old May 20, 2002 | 05:23 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Weird... I can use first on my trans... even on my original transmission, without the shift kit. When you pull the stick back from 2nd, it doesn't downshift?
Old May 20, 2002 | 06:30 PM
Nope, can't pull it back any further. My friend has a 2nd gen V6 and it was just a plastic block that kept him from pulling the shifter lower than 2nd, and he was able to cut it out. I don't know what the f*** is with mine, its nothing i can cut out. I haven't looked at it in a while, but I couldn't figure it out.
Old May 20, 2002 | 07:46 PM
Ovrclck350's Avatar
I can pull mine down, but unless I'm going under a certain MPH, it doesn't actually downshift...that's a safety feature though.
Old May 20, 2002 | 09:11 PM
maybe my transmission is just screwed up, but I know of 2 other peoples' who do the same (both 3rd gen camaros), has anyone else seen this?
Old May 20, 2002 | 09:43 PM
RPS's Avatar
RPS
i remember reading about a similar problem... it turned out, that there was a plastic blocker disabeling you to physicaly move the shifter to 1st, the person cut it out and could shift to first... not shure i understand thats what your problem is.
edit: oops you already tried. guess thats why you read the message before you answer
Old May 20, 2002 | 09:45 PM
I'll check it out again, the last time i checked it out almost 2 years ago when i just turned 16 and didint know S*** about cars, that might be the solution
Old May 21, 2002 | 02:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
It could also be that your shift cable (or shift linkage, on the driver's side of the trans pan) is loose or busted. You're saying you can't put the stick in 1st gear at ALL? Even when stopped? That's weird. You might want to ask about this on the trans board.
It's still the stock shifter, right? You should be able to get to first gear with the stick... I never heard of GM blocking that off. If that were the case, your gear selector would read "2 D OD N R P" instead of "1 2 D OD N R P". (My B&M Megashifter reads "1 2 3 D N R P", I'm so glad they did that- to me, it's the way the gears should read!)
Old May 21, 2002 | 08:59 PM
yep stock shifter
I asked already on the trans board, no response
The cable from the trans to the shifter might be made for a 3spd? maybe? or just the wrong cable?
The selector reads 1 2 D OD
Old May 22, 2002 | 04:07 PM
Ok, just took off the shifter cover plate or whatever, and like i said there was no block ( I think) but there is a piece bolted up that looks kinda suspicious. Could one of you guys post a picture of what it looks like under your shifter cover so i could compare?
Old May 22, 2002 | 04:08 PM
should it look the same in there as it would in my friends 305 camaro?
Old May 22, 2002 | 05:37 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yes, it should. Did you inspect the linkage and shift cable yet?
Old May 22, 2002 | 09:29 PM
nothing seems out of place, I'm gonna check out my friends 305 and see what it looks like
Old May 23, 2002 | 07:49 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
A look probably won't tell you anything... (sigh) Okay, off the top of my head, how to inspect your cable & linkage:
Remove the console cap, disconnect the shift cable from the shifter. See if you can pull the shifter into first with the cable disconnected. If you can't, the shifter is busted. You'll be amazed at how easily the shifter moves with the cable unhooked; this is normal.
If you can, then go underneath the car. Disconnect the shift cable from the trans shift lever. Move the trans shift lever by hand, see if you can get to all of the gears.
If you can get to first, then it's probably the shift cable. Since both ends are now disconnected, work the cable in & out, and "feel" for binding. If no binding, put the shifter in first. Put the trans shift lever into first (swing it all the way down and back). Try to make the cable line up with both the trans shift lever and the shifter connection. If the cable won't line up...
Old May 23, 2002 | 11:42 PM
ok I'll give that a try, I had a similar experience with the accelerator cable (I couldn't floor it!) maybe the guy before didnt know how to buy the right length of cable
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
georgiaslim45
Sep 9, 2015 08:11 PM
scottmoyer
Sep 7, 2015 07:06 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
