did you know that ?
Old Jun 6, 2002 | 07:24 PM
WaynesRS's Avatar
did you know that ?
Mom called me today , and said "my car is overheating " I went to check it out . I thought "thermastat or radiator cap " . My Dad called my Uncle to talk to him about it and he said "sounds like its the serpentine belt to me sence its not hard to stear . I replaced the belt , it was worn , bad enough , but not real bad like I have seen them before . But I think what happened is where some of the groves in the belt were pretty bad worn and maybe they weren't spinning the waterpump pully like it should have . I changed the belt and drove it home a good 7 miles and never overheated and never smoked-from being overheated ! ........I have a question for you guys also . Her airconditioner compressor is not coming on , the ac blows , just does not blow cold air . Will having no freon , or very low freon make the compressor not work ? I wouldn't think that it could but I just want to make sure on this guys . Thanx as always !
Old Jun 6, 2002 | 07:50 PM
CaliCamaroRS's Avatar
Engine: LH0 3.1L
The back side of the belt spins the water pump, so worn teeth wouldn't affect it.
Yes, the compressor will not spin if freon is low or empty.
EDIT: Wait, we're not talking about the thirdgen are we? Then disregard the belt comment.
Old Jun 6, 2002 | 09:18 PM
WaynesRS's Avatar
Opps , Sorry . Forgot to mention it's on an 89 3.1 grandprix ....2.8/3.1 pretty close engine ...lol ...wasn't thinking ....
I was telling Dad the coolant was real dirty when I checked it , it had some sorta baby $hit brown on part of the cap and around the hole in the radiator .I told Dad I am was going to flush it this weekend b/c of that . If the belt , the side with the grooves is not facing that way to spin the waterpump , what caused it to smoke like that ? then not smoke after I changed the belt ? Strange huh ?
Thanx for the help Dan
oh Dan , would the same thing be the case on Mom's 89 grand prix 3.1 with low or no freon causing the compressor not to spin ? Thanx man !
Old Jun 6, 2002 | 10:27 PM
Camar_Hunter_c's Avatar
yes there is a switch that controls the clutch for the A/C compressor. If it reads no pressure/low pressure it will not engauge the A/C compressor to save it from melting.
Old Jun 8, 2002 | 07:19 AM
I Cant Drive 55's Avatar
On the A/C sometimes the pressure switches go bad, but not often . To check it : Pull the two prong plug off of the switch which should be located on the A/C filter drier . Use a jumper wire to connect the two spades on the wire. Turn on A/C . The compressor should come on , check to see if you have cold air coming out of the vents . If you dont , no freon or filter drier plugged up. If the air is cold than pressure switch is bad.
If the compressor doesnt come on at all than compressor clutch is bad or a cut in the wire.
As Far as the coolant . If it has DEX-COOL ( the orange stuff ) than the baby crap looking stuff is normal. If it the green anti freeze it may have water pump lube additive in it.
