wiring
Old Jul 24, 2002 | 01:12 PM
widow_maker89's Avatar
wiring
Does anyone here have a wireing harness map? more specifically, i need to know exactly what wire do what on the large driver side plug the goes nder the dash, ot one the ecm side, i have put the 2.8 in my gmc jimmy, plumbed it,and now i am just left with the wireing, it may already run, i just need to know before i try to start it. Thanks in advance Matt manglos..oh btw the car theengine came ot of is a 1985 Pontiac Firebird 2.8 v6 automatic
Old Jul 24, 2002 | 01:31 PM
Dale's Avatar
Car: 1991 Camaro RS Vert
Engine: 350 S-TPI
Axle/Gears: GU5/G80/J65
I have a diagram (2 to be exact) but have no scanner to help you. They are in the chiltons and haynes manuals you can get at autozone, orileys, advanced, pepboys, etc.
Old Jul 24, 2002 | 03:18 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I believe the driver's side plug on the f-body has nothing to do with the engine. All the ECM wires from the main engine harness go through the passenger-side's passthru and into the ECM. A third part of the fbody's driver's side connector is the lights harness.
Old Jul 24, 2002 | 03:34 PM
Dale's Avatar
Engine: 350 S-TPI
hey widow maker, did you post on mys10.com also?? If so I replyed on their
Old Jul 24, 2002 | 07:38 PM
Y yes.... actually I did, ok fuel tanks are the same from 82-93 with fuel inj or carburation, height wise, the fuel pumps are the same and bolt in wise agian they are the same..... sooo what i am going to do is buy the frebird fuel pump 65 PSI 20GPH, and install it into the fuel tank.... this shoudl take care of any problems that i may have run into, the tbi s10 2.8 pumps only put out 15 ps but again 20 GPH. I will keep you posted as to what happens.... and for whoever said that the left side didnt have to do with the engine, but the dash rather you are 95% right, the fuel pump circiut and ecm circuit still run through there and mount/plug into the stock fuse panel, this is why i need a map of what wire are nessesary, i can put in my own waterproof fuses and leave it in the engine bay, but i need to know what fuses need to installed, what wires to fuse to what ire and the like. I also need to run the wires back to the fuel pump....... again through the left side engine plug through the firewall.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
