Cyl Heads
Old Aug 2, 2002 | 03:44 AM
nj88v6's Avatar
Cyl Heads
How hard is it to rebuild the cyl heads with new springs and rockers and all? What parts will I need? What special tools will I have to get?
Is it worth it to find a place to pick up remanufactured heads? If so, does anyone know a good place to get them?
Thanks.
Old Aug 2, 2002 | 09:15 AM
MDv6man's Avatar
Car: 1983, 1986
Engine: 2.8 2bbl, 2.8 MPFI
Transmission: 200C 3 speed, 700R4
Axle/Gears: 3.08, 3.42
Rebuilding the heads with new valve and springs and stem seals is not hard if you have a valve spring compressor and can get the valves, spring retainers, etc. The problem comes in if the head itself is warped or the seats are damaged. There are also issues if the head is cracked. The most cost effective solution would be to remove the rocker arms and studs and take the heads to a reputable machine shop. They can check for cracks, clean and do a full valve job for around $300. I am not sure how much remanufactured heads go for but many stores and shops can order them.
Here is who machines my cylinder heads. They do an excellent job
http://www.accuratepower.com/
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
