Backfiring... from TB
Old Aug 8, 2002 | 10:33 PM
nj88v6's Avatar
Well, I pulled off the intake hose and ran the car, and it seems like there is definitely a backfire or some sort of popping coming from what seems like the TB opening. What could cause this?
Remember, I just tore apart the motor to the head gaskets for a replacement...
Thanks..
Old Aug 9, 2002 | 02:35 AM
joezero's Avatar
Car: See pic above
Engine: Too Small
Transmission: Broken
I had a vacuum leak that caused the same thing. Check for the vacuum hose from the back of the plenum to the brake booster. If all your vacuum lines are good, then I would check the timing.
Old Aug 9, 2002 | 10:25 AM
nj88v6's Avatar
Vac hoses
Hmmm... I'll have to check. I have been puling that one on and off because that elbow or t at the back of the plenum was loose, which i tighened... Maybe it tore...
Old Aug 9, 2002 | 03:16 PM
LT1guy's Avatar
Car: 1987 Trans Am
Did you reset the timing, or just mark the dist and put it back the same way? You might have the timing off a little; that would be my first guess.
Old Aug 9, 2002 | 04:18 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I was also thinking ignition, or, could be a lack of fuel (dying pump).
