TOMP or someone please post a pic for me
Old Aug 11, 2002 | 12:58 AM
Ovrclck350's Avatar
I need to see where the temperature sensor plugs in...I think I accidentally disconnected it, and I can't remember where it's at.....thanks.
Old Aug 11, 2002 | 01:16 AM
Ovrclck350's Avatar
Also, could someone tell me how to adjust the TV cable? I read the tech article, but it seemed vague. Should the key be on when I do it? Do I push the actual WIRE in or?
Old Aug 11, 2002 | 03:26 AM
Kj Rockz's Avatar
From: Mililani, HI USofA Search Posts: 2848.............. Whore Posts: 47.................. Magical Whore Posts: 1
Car: 91 Camaro 77K
Engine: 3.1 Vslick
The temp sensor plugs into the sensor. The sensor is right below the intake, to the right a little...
Old Aug 11, 2002 | 07:30 AM
I Cant Drive 55's Avatar
On the TV cable there is a block where it mounts on the bracket . on that block there is a large button that you press that releases the outer sleeve of the cable so that you can slide the outer sleeve in and out.
Push the button and slide the outer sleeve all the way in towards the bracket .
Get in the car , with the ignition OFF , press the gas pedal all the way to the floor and release.
This automatically adjusts the cable.
Sometimes I have had to adjust the cable slightly by hand from this point to get the shift to my liking.
Old Aug 13, 2002 | 05:20 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yeah, key off, you'll see everything move when you push in that "D-shaped" button with a screwdriver. (I've never been able to push mine in with my thumb.) The cable has a slider on it that can "pop out" towards the front of the throttle linkage. You'll see a notched rectangle, a little black oval, and the cable sticking out of the middle of these. That whole piece (rectangle,oval,cable) moves in/out of the TV adjuster.
Which temp sensor? There's three. One at the back outer corner of the passenger head, single green (i think) wire, that's for the electric fan. One at the front outer corner of the driver's side had, single green wire, for the dashboard idiot light or temp gauge. Third is where KJRockz said, I think a two wire connector, one yellow one black? Been a while since I stared at that one.
87iroctheo
Dec 4, 2016 11:47 AM
aaron7
Aug 17, 2016 06:02 PM
pimprs
Aug 24, 2015 11:20 PM
BurlyChev
Aug 22, 2015 01:52 PM
ryanz281988
Members Camaros
Aug 8, 2015 06:45 AM
